Hackaday.io Hackaday.io
Sign up Log in
Binary Seven-Segment Wristwatch
A minimalist binary wristwatch that tells time using a 7-segment display—why use 6 digits when 3 will do? Save segments, embrace binary!
oleksandr-yOleksandr Y.
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
3 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
533
0
3
7
Team (1)
  • oleksandr-yOleksandr Y.
Join this project's team
  • Source code
hardware
ongoing project
WAtch wristwatch low power stm8 Binary watch binary wearable
This project is submitted for
  • Hackaday.com Tip Line
  • One Hertz Challenge
This project was created on 07/26/2025 and last updated 7 months ago.
Description
This is a wristwatch that displays time in binary using a single 7-segment display. Each segment represents a binary multiplier: segment B is 1, C is 2, D is 4, and so on. This minimalistic design reduces the need for multiple digits or full character rendering—just a few cleverly lit segments tell you everything. The PCB is fully custom, and I’ve stripped the design down to the essentials, using a microcontroller, several buttons, and a compact LCD to keep the form factor slim and wearable. The watch is strapped with simple wires for an ultra-light look :). Think of it as a cyberpunk take on timekeeping, or a nerdy challenge to anyone who tries to read your watch at a glance! Why waste precious segments when binary can do more with less? After all, why use 6 digits when you can get by with just 3 and a bit of brainpower?
Details
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
In this guide, we will use the Omega to retrieve and display stock prices.
Project Owner Contributor
Onion Omega Stock Ticker
onionioOnion.io
The 2018 Hackaday Prize
The first digital watches had this red bubble display, you need to push a button to see the time.
Retro Wristwatch
saarbastlersaarbastler
Cistercian digital clock with minimalist display
CIS-4
danjovicdanjovic
A retro-techtacular clock that displays time sequentially using illuminated ionized neon gas.
Cloxie | A 1×1 Nixie-tube Clock
acrobotic-industriesACROBOTIC Industries
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Binary Seven-Segment Wristwatch", please tell us the reason.
Send message
Remove Member
