Pico Analog Clock
Raspberry Pi Pico NTP Clock uses Network Time Protocol to stay in time
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
Raspberry Pi Pico NTP Clock uses Network Time Protocol to stay in time This uses a Raspberry Pi Pico W, the superb MMBASIC for the Pico, and a Waveshare Pico-Eval-Board. Download source code from GitHub, follow the instructions in the MMBASIC manual to set up network access for the Pico/W, and you'll get a clock that checks in with NTP once an hour and displays date and time. Here is the board setup: WebMite MMBasic Version 5.07.08b1 OPTION SYSTEM SPI GP10,GP11,GP12 OPTION AUTORUN 4 OPTION COLOURCODE ON OPTION POWER PWM ON OPTION HEARTBEAT OFF OPTION CPUSPEED (KHz) 250000 OPTION DISPLAY 50, 132 OPTION LCDPANEL ILI9488W, RPORTRAIT,GP8,GP15,GP9,GP13 OPTION WIFI mywifinetworkname, *************** OPTION TOUCH GP16,GP17 GUI CALIBRATE 0, 3946, 211, -1287, 853 OPTION SDCARD GP22, GP5, GP18, GP19
