Pictures of the Assembled PCB for the LoRaTube V4
A project log for LoRaTube
A compact and rugged LoRa repeater designed for long-range communication and 5+ years of off-grid operation using only alkaline batteries.
bertrand-selvaBertrand Selva 11/17/2025 at 09:530 Comments
Here are a few photos I received this morning of the fully assembled PCB, manufactured by PCBWay.
This is Revision V4.
The build quality is excellent ; clean soldering, crisp edges, and a layout that finally looks exactly as intended.
Once the board is in my hands, I will publish a detailed bring-up report for this V4 revision as for the V3 revision: power-on tests, rail validation, firmware loading, radio checks, and early measurements.
More to come.
