Separation between D pack and PCB
A project log for LoRaTube
A compact and rugged LoRa repeater designed for long-range communication and 5+ years of off-grid operation using only alkaline batteries.
bertrand-selvaBertrand Selva 12/04/2025 at 19:440 Comments
I will complete the log later with the elements I was able to collect from the article on hackaday.com about the LoRaTube. There were a lot of comments about the long-term behavior of D cells. You’re right, I do have a modification to address this issue.
In the meantime, here is, through this diagram, the answer to one of the issues that was raised: there is indeed a clear separation between the electronics (which are in any case above the batteries) and the batteries, via the part that holds the 50 mm tube and looks like a coffee cup.
