GestureBot: ROS2 Computer Vision Mobile Platform
A mobile robot that responds to human gestures, facial expressions using real-time pose estimation and gesture recognition & intuitive HRI
Control robots through natural body language with this ROS 2-powered MediaPipe vision system. Built for Raspberry Pi 5 with iRobot Create 2, GestureBot translates hand gestures and body poses into real-time navigation commands. Key Features: ✅ Gesture Recognition — 7 hand gestures (thumbs up/down, victory, fist, open palm) with 21-point landmark tracking ✅ 4-Pose Navigation — Body pose control: arms raised (forward), pointing (turn), t-pose (stop) ✅ Object Detection — EfficientDet-Lite detecting 80 COCO classes with color-coded confidence ✅ Person Following — Autonomous tracking with distance maintenance (0.8m–5.0m) ✅ Nav2 Integration — Seamless ROS 2 Navigation stack connectivity ✅ Safety Systems — Emergency stops, timeouts, velocity smoothing, confidence thresholds
Refer to the README for the details.
  • Building an Autonomous Person Following System with Computer Vision
    Vipin M • 08/15/2025 at 14:47 • 0 comments
    When your robot becomes your shadow – implementing intelligent person following with object detection and ROS 2
    Imagine a robot that follows you around like a loyal companion, maintaining the perfect distance whether you're walking through a warehouse, giving a facility tour, or need hands-free assistance. While gesture and pose control are great for direct commands, sometimes you want your robot to simply tag along autonomously. That's exactly what we've built into GestureBot – a standalone person following system that transforms any detected person into a moving target for smooth, intelligent pursuit.
    The Appeal of Autonomous Following
    Person following robots aren't just cool demos – they solve real problems. Consider a hospital robot carrying supplies that needs to follow a nurse through rounds, a security robot accompanying a guard on patrol, or a service robot helping someone navigate a large facility. In these scenarios, constant manual control becomes tedious and impractical.
    The key insight is that following behavior should be completely autonomous once activated. No gestures, no poses, no commands – just intelligent tracking that maintains appropriate distance while handling the inevitable challenges of real-world environments: people walking behind obstacles, multiple individuals in the scene, varying lighting conditions, and the need for smooth, non-jerky motion that won't startle or annoy.
    Leveraging Existing Object Detection Infrastructure
    Rather than building a specialized person tracking system from scratch, we cleverly repurpose GestureBot's existing object detection capabilities. The system already runs MediaPipe's EfficientDet model at 5 FPS, detecting 80 different object classes including people with confidence scores and precise bounding boxes.
    This architectural decision provides several advantages: proven stability, existing performance optimizations, and the ability to simultaneously track people and obstacles. The object detection system publishes to /vision/objects, providing a stream of detected people that our following controller can consume.
    # Object detection provides person detections like this:
    DetectedObject {
        class_name: "person"
        confidence: 0.76
        bbox_x: 145        # Top-left corner
        bbox_y: 89
        bbox_width: 312    # Bounding box dimensions
        bbox_height: 387
     The person following controller subscribes to this stream and implements sophisticated logic to select, track, and follow the most appropriate person in the scene.
    Smart Person Selection: More Than Just "Pick the Biggest"
    When multiple people appear in the camera view, the system needs to intelligently choose who to follow. Our selection algorithm uses a weighted scoring system that considers three key factors:
    Size Score (40% weight): Larger bounding boxes typically indicate closer people or those more prominently positioned in the scene. This naturally biases toward the person most likely intended as the target.
    Center Score (30% weight): People closer to the image center are preferred, following the reasonable assumption that users position themselves centrally when activating following mode.
    Confidence Score (30% weight): Higher detection confidence indicates more reliable tracking, reducing the chance of following false positives or poorly detected individuals.
    def select_initial_target(self, people):
        scored_people = []
        for person in people:
            # Normalize bounding box to 0-1 coordinates
            size_score = (person.bbox_width * person.bbox_height) / (640 * 480)
            center_x = (person.bbox_x + person.bbox_width/2) / 640
            center_score = 1.0 - abs(center_x - 0.5) * 2
            total_score = (size_score * 0.4 +
                          center_score * 0.3 +
                          person.confidence * 0.3)
            scored_people.append((person, total_score))
        return max(scored_people, key=lambda x: x[1])[0]
    Once a target is selected, the system maintains tracking continuity by matching people across frames based on position prediction, preventing erratic switching between similar individuals.
    Distance...
  • 4-Pose Navigation with MediaPipe
    Vipin M • 08/15/2025 at 14:41 • 0 comments
    When hand gestures aren't enough, your whole body becomes the remote control
    We've all been there – trying to control a robot with hand gestures while your hands are full, wearing gloves, or when lighting conditions make finger detection unreliable. What if your robot could understand your intentions through simple body poses instead? That's exactly what we've implemented in the latest iteration of GestureBot, a Raspberry Pi 5-powered robot that now responds to four distinct body poses for intuitive navigation control.
    Why Body Poses Beat Hand Gestures
    While hand gesture recognition is impressive, it has practical limitations. Gestures require clear hand visibility, specific lighting conditions, and can be ambiguous when multiple people are present. Body poses, on the other hand, are larger, more distinctive, and work reliably even when hands are obscured or busy with other tasks.
    Consider a warehouse worker guiding a robot while carrying boxes, or a surgeon directing a medical robot while maintaining sterile conditions. Full-body pose detection opens up robotics applications where traditional gesture control falls short.
    The Technical Foundation: MediaPipe Pose Detection
    At the heart of our system lies Google's MediaPipe Pose Landmarker, which provides real-time detection of 33 body landmarks covering the entire human skeleton – from head to toe. Running on a Raspberry Pi 5 with 8GB RAM and a Pi Camera Module 3, we achieve stable 3-7 FPS pose detection at 640x480 resolution.
    The MediaPipe model excels at tracking key body points including shoulders, elbows, wrists, hips, and the torso center. What makes this particularly powerful for robotics is the consistency of landmark detection even with partial occlusion or varying lighting conditions.
    # Core MediaPipe configuration optimized for Pi 5
    pose_landmarker_options = {
        'base_options': BaseOptions(model_asset_path='pose_landmarker.task'),
        'running_mode': VisionRunningMode.LIVE_STREAM,
        'num_poses': 2,  # Track up to 2 people
        'min_pose_detection_confidence': 0.5,
        'min_pose_presence_confidence': 0.5,
        'min_tracking_confidence': 0.5
    Simplicity Through Four Poses
    After experimenting with complex pose vocabularies, we settled on four reliable poses that provide comprehensive robot control:
    🙌 Arms Raised (Forward Motion): Both arms extended upward above shoulder level triggers forward movement at 0.3 m/s. This pose is unmistakable and feels natural for "go forward."
    👈 Pointing Left (Turn Left): Left arm extended horizontally while right arm remains down commands a left turn at 0.8 rad/s. The asymmetry makes this pose highly distinctive.
    👉 Pointing Right (Turn Right): Mirror of the left turn – right arm extended horizontally triggers rightward rotation.
    🤸 T-Pose (Emergency Stop): Both arms extended horizontally creates the universal "stop" signal, immediately halting all robot motion.
    The pose classification algorithm analyzes shoulder and wrist positions relative to the torso center, using angle calculations and position thresholds to distinguish between poses:
    def classify_pose(self, landmarks):
        # Extract key landmarks
        left_shoulder = landmarks[11]
        right_shoulder = landmarks[12]
        left_wrist = landmarks[15]
        right_wrist = landmarks[16]
        # Calculate arm angles relative to shoulders
        left_arm_angle = self.calculate_arm_angle(left_shoulder, left_wrist)
        right_arm_angle = self.calculate_arm_angle(right_shoulder, right_wrist)
        # Classify based on arm positions
        if left_arm_angle > 60 and right_arm_angle > 60:
            return "arms_raised"
        elif abs(left_arm_angle) < 30 and abs(right_arm_angle) < 30:
            return "t_pose"
        # ... additional classification logic
    ROS 2 Integration: From Pose to Motion
    The system architecture follows a clean pipeline: pose detection → classification → navigation commands → smooth motion control. Built on ROS 2 Jazzy, the implementation uses three main components:
    Pose Detection Node: Processes camera frames through MediaPipe,...
  • Gesture based Navigation
    Vipin M • 08/14/2025 at 15:54 • 0 comments
    Gesture-controlled robotics represents a compelling intersection of computer vision, human-robot interaction, and real-time motion control. I developed GestureBot as a comprehensive system that translates hand gestures into precise robot movements, addressing the unique challenges of responsive detection, mechanical stability, and modular architecture design.
    The project tackles several technical challenges inherent in gesture-controlled navigation: achieving sub-second response times while maintaining detection stability, preventing mechanical instability in tall robot form factors through acceleration limiting, and creating a modular architecture that supports future multi-modal integration. My implementation demonstrates how MediaPipe's gesture recognition capabilities can be effectively integrated with ROS2 navigation systems to create a responsive, stable, and extensible robot control platform.
    System Architecture
    I designed GestureBot with a modular architecture that separates gesture detection from motion control, enabling flexible deployment and future expansion. The system consists of two primary components connected through ROS2 topics:
    Core Components
    Gesture Recognition Module: Handles camera input and MediaPipe-based gesture detection, publishing stable gesture results to /vision/gestures. This module operates independently and can function without the motion control system for testing and development.
    Navigation Bridge Module: Subscribes to gesture detection results and converts them into smooth robot motion commands published to /cmd_vel. This separation allows the navigation bridge to potentially receive input from multiple detection sources in future implementations.
    Data Flow Architecture
    Camera Input → MediaPipe Processing → Gesture Stability Filtering → /vision/gestures
    /cmd_vel ← Acceleration Limiting ← Velocity Smoothing ← Motion Mapping ←──┘
    The modular design enables independent operation of components. I can run gesture detection without motion control for development, or use external gesture sources with the navigation bridge. This architecture prepares the system for Phase 4 multi-modal integration where object detection and pose estimation will feed into the same navigation bridge.
    Launch File Structure
    I implemented separate launch files for each component:
    • gesture_recognition.launch.py: Camera and gesture detection only
    • gesture_navigation_bridge.launch.py: Motion control and navigation logic
    • Future: multi_modal_navigation.launch.py: Integrated multi-modal system
    This separation provides deployment flexibility and simplifies parameter management for different robot configurations.
    Technical Implementation
    MediaPipe Integration for Hand Gesture Detection
    I integrated MediaPipe's gesture recognition model using a controller-based architecture that handles the MediaPipe lifecycle independently from ROS2 infrastructure. The implementation uses MediaPipe's LIVE_STREAM mode with asynchronous processing for optimal performance:
    class GestureRecognitionController:
        def __init__(self, model_path: str, confidence_threshold: float, max_hands: int, result_callback):
            self.model_path = model_path
            self.confidence_threshold = confidence_threshold
            self.max_hands = max_hands
            self.result_callback = result_callback
            # Initialize MediaPipe gesture recognizer
            base_options = python.BaseOptions(model_asset_path=self.model_path)
            options = vision.GestureRecognizerOptions(
                base_options=base_options,
                running_mode=vision.RunningMode.LIVE_STREAM,
                result_callback=self._mediapipe_callback,
                min_hand_detection_confidence=self.confidence_threshold,
                min_hand_presence_confidence=self.confidence_threshold,
                min_tracking_confidence=self.confidence_threshold,
                num_hands=self.max_hands
            self.recognizer = vision.GestureRecognizer.create_from_options(options)
    The controller processes camera frames asynchronously and extracts gesture classifications, hand landmarks, and handedness information....
  • Building a 33-Point Human Skeleton Tracker
    Vipin M • 08/14/2025 at 15:20 • 0 comments
    Most robotics vision systems treat humans as simple bounding boxes – "person detected, avoid obstacle." But humans are dynamic, expressive, and predictable if you know how to read body language. A person leaning forward might be about to walk into the robot's path. Someone pointing could be giving directional commands. Arms raised might signal "stop."
    I needed a system that could:
    • Track 33 distinct body landmarks in real-time
    • Handle multiple people simultaneously (up to 2 poses)
    • Run headless on embedded hardware without X11 dependencies
    • Integrate cleanly with my existing ROS 2 navigation stack
    • Provide visual feedback for development and debugging
    The Core Architecture
    The heart of my implementation is a modular ROS 2 node that wraps MediaPipe's PoseLandmarker model. I chose a composition pattern to keep the ROS infrastructure separate from the MediaPipe processing logic:
    class PoseDetectionNode(MediaPipeBaseNode, MediaPipeCallbackMixin):
        def __init__(self, **kwargs):
            MediaPipeCallbackMixin.__init__(self)
            super().__init__(
                node_name='pose_detection_node',
                **kwargs
            # Initialize the pose detection controller
            self.controller = PoseDetectionController(
                model_path=self.model_path,
                confidence_threshold=self.confidence_threshold,
                max_poses=self.max_poses,
                logger=self.get_logger()
    The PoseDetectionController handles all MediaPipe-specific operations:
    class PoseDetectionController:
        def __init__(self, model_path: str, confidence_threshold: float, max_poses: int, logger):
            self.logger = logger
            # Configure MediaPipe options
            base_options = python.BaseOptions(model_asset_path=model_path)
            options = vision.PoseLandmarkerOptions(
                num_poses=max_poses,
                min_pose_detection_confidence=confidence_threshold,
                min_pose_presence_confidence=confidence_threshold,
                min_tracking_confidence=confidence_threshold,
                result_callback=self._pose_callback
            self._landmarker = vision.PoseLandmarker.create_from_options(options)
    The 33-Point Pose Model
    MediaPipe's pose model detects 33 landmarks covering the entire human body:
    • Face: Nose, eyes, ears (5 points)
    • Torso: Shoulders, hips, center points (6 points)
    • Arms: Shoulders, elbows, wrists (6 points)
    • Hands: Wrist, thumb, fingers (10 points)
    • Legs: Hips, knees, ankles, feet (6 points)
    Each landmark provides normalized (x, y) coordinates plus a visibility score, giving rich information about human pose and orientation.
    Handling MediaPipe's Async Processing
    One of the trickier aspects was properly handling MediaPipe's asynchronous LIVE_STREAM mode. The pose detection happens in a separate thread, with results delivered via callback:
    def _pose_callback(self, result: vision.PoseLandmarkerResult,
                       output_image: mp.Image, timestamp_ms: int):
        """Handle pose detection results from MediaPipe."""
        try:
            # Convert MediaPipe timestamp to ROS time
            ros_timestamp = self._convert_timestamp(timestamp_ms)
            # Process pose landmarks
            pose_msg = PoseLandmarks()
            pose_msg.header.stamp = ros_timestamp
            pose_msg.header.frame_id = 'camera_frame'
            if result.pose_landmarks:
                pose_msg.num_poses = len(result.pose_landmarks)
                # Handle MediaPipe's pose landmark structure variations
                for pose_landmarks in result.pose_landmarks:
                    try:
                        # MediaPipe structure can vary between versions
                        if hasattr(pose_landmarks, '__iter__') and not hasattr(pose_landmarks, 'landmark'):
                            landmarks = pose_landmarks  # Direct list access
                        else:
                            landmarks = pose_landmarks.landmark  # Attribute access
                        for landmark in landmarks:
                            point = Point()
                            point.x = landmark.x
                            point.y = landmark.y
                            point.z = landmark.z
                            pose_msg.landmarks.append(point)
                    except Exception as e:
                        self.logger.warn(f'Pose landmark processing error: {e}')
                        continue
            # Publish results
            self.pose_publisher.publish(pose_msg)
            self.logger.error(f'Pose callback error: {e}')\
    Performance Reality Check: 3-7 FPS on Pi 5
    Let me be honest about performance – this isn't going...
  • Implementing Real-Time Gesture Recognition for Robot Control
    Vipin M • 08/13/2025 at 03:40 • 0 comments
    System Overview and Architecture
    The GestureBot gesture recognition system is built on a modular ROS 2 architecture that combines MediaPipe's powerful computer vision capabilities with efficient real-time processing optimized for embedded systems. The core system processes camera input at 15 FPS, detects hand gestures with 21-point landmark tracking, and translates recognized gestures into navigation commands for autonomous robot control.
    Key Performance Metrics
    Through extensive testing and optimization, I've achieved the following performance characteristics on Raspberry Pi 5:
    • Processing Rate: 15 FPS @ 640x480 resolution
    • Gesture Recognition Latency: <100ms from detection to command
    • Hand Landmark Accuracy: 21-point skeleton with sub-pixel precision
    • System Resource Usage: <25% CPU utilization during active processing
    • Memory Footprint: ~150MB including MediaPipe models and ROS 2 overhead
    MediaPipe Integration with ROS 2
    The foundation of the gesture recognition system is a robust integration between MediaPipe's gesture recognition capabilities and ROS 2's distributed computing framework. I implemented this using a callback-based architecture that maximizes performance while maintaining system responsiveness.
    Core Architecture Components
    The system consists of several key components working in concert:
    GestureRecognitionNode: The primary ROS 2 node that inherits from MediaPipeBaseNode, providing standardized MediaPipe integration patterns across the vision system.
    MediaPipe Gesture Recognizer: Utilizes the pre-trained gesture_recognizer.task model for real-time gesture classification with confidence scoring.
    Unified Image Viewer: A multi-topic display system that can simultaneously show gesture recognition results, hand landmarks, and performance metrics.
    Callback-Based Processing Pipeline
    I implemented the MediaPipe integration using an asynchronous callback pattern that ensures optimal performance:
    def initialize_mediapipe(self) -> bool:
        """Initialize MediaPipe gesture recognizer with callback processing."""
        try:
            # Configure gesture recognizer options
            options = mp_vis.GestureRecognizerOptions(
                base_options=mp_py.BaseOptions(model_asset_path=self.model_path),
                running_mode=mp_vis.RunningMode.LIVE_STREAM,
                result_callback=self._process_callback_results,
                num_hands=self.max_hands,
            self.gesture_recognizer = mp_vis.GestureRecognizer.create_from_options(options)
            return True
            self.get_logger().error(f"Failed to initialize MediaPipe: {e}")
            return False
    This approach uses MediaPipe's LIVE_STREAM mode with detect_async() for optimal performance, avoiding blocking operations in the main processing thread.
    Hand Landmark Detection System
    The gesture recognition system implements comprehensive 21-point hand landmark tracking, providing detailed skeletal information for each detected hand. This landmark data serves dual purposes: gesture classification input and visual feedback for system debugging.
    21-Point Hand Skeleton
    MediaPipe's hand landmark model provides 21 key points representing the complete hand structure:
    • Wrist (0): Base reference point
    • Thumb (1-4): Complete thumb chain from base to tip
    • Index Finger (5-8): Four points from base to fingertip
    • Middle Finger (9-12): Complete middle finger structure
    • Ring Finger (13-16): Four-point ring finger chain
    • Pinky (17-20): Complete pinky finger structure
    Landmark Visualization Implementation
    I implemented a comprehensive visualization system that draws both individual landmarks and connecting skeleton lines:
    def draw_hand_landmarks(self, image: np.ndarray, hand_landmarks_list) -> None:
        """Draw complete hand landmarks with skeleton connections."""
        try:
            if not hand_landmarks_list:
                return
            height, width = image.shape[:2]
            for hand_index, hand_landmarks in enumerate(hand_landmarks_list):
  • Manual Object Detection Annotations in GestureBot
    Vipin M • 08/11/2025 at 05:04 • 0 comments
    When developing the GestureBot vision system, I encountered a common challenge in robotics computer vision: balancing performance with visualization flexibility. While MediaPipe provides excellent object detection capabilities, its built-in annotation system proved limiting for our specific visualization requirements. This post details how I implemented a custom manual annotation system using OpenCV primitives while maintaining MediaPipe's high-performance LIVE_STREAM processing mode.
    Problem Statement: Why Move Beyond MediaPipe's Built-in Annotations
    MediaPipe's object detection framework excels at inference performance, but its visualization capabilities presented several limitations for our robotics application:
    MediaPipe Annotation Limitations
    • Limited customization: Fixed annotation styles with minimal configuration options
    • Inconsistent output: LIVE_STREAM mode doesn't always provide reliable output_image results
    • Performance overhead: Built-in annotations add processing latency in the inference pipeline
    • Inflexible styling: No control over color schemes, font sizes, or confidence display formats
    Our Requirements
    For GestureBot's vision system, I needed:
    • Color-coded confidence levels for quick visual assessment
    • Percentage-based confidence display for precise evaluation
    • Consistent annotation rendering regardless of detection confidence
    • Minimal performance impact on the real-time processing pipeline
    • Full control over visual styling to match our robotics interface
    Technical Implementation: Manual Annotation Architecture
    The solution involved decoupling MediaPipe's inference engine from the visualization layer, creating a custom annotation system that operates on the original RGB frames.
    System Architecture
    # High-level flow
    RGB Frame → MediaPipe Detection (LIVE_STREAM) → Manual Annotation → ROS Publishing
     The key insight was to preserve MediaPipe's asynchronous detect_async() processing while applying custom annotations to the original RGB frames, rather than relying on MediaPipe's output_image.
    Core Implementation: Manual Annotation Method
    def draw_manual_annotations(self, image: np.ndarray, detections) -> np.ndarray:
        Manually draw bounding boxes, labels, and confidence scores using OpenCV.
        Args:
            image: RGB image array (H, W, 3)
            detections: MediaPipe detection results
        Returns:
            Annotated RGB image array
        if not detections:
            return image.copy()
        annotated_image = image.copy()
        for detection in detections:
            # Get bounding box coordinates
            bbox = detection.bounding_box
            x_min = int(bbox.origin_x)
            y_min = int(bbox.origin_y)
            x_max = int(bbox.origin_x + bbox.width)
            y_max = int(bbox.origin_y + bbox.height)
            # Ensure coordinates are within image bounds
            x_min = max(0, min(x_min, width - 1))
            y_min = max(0, min(y_min, height - 1))
            x_max = max(0, min(x_max, width - 1))
            y_max = max(0, min(y_max, height - 1))
            # Get the best category (highest confidence)
            if detection.categories:
                best_category = max(detection.categories, key=lambda c: c.score if c.score else 0)
                class_name = best_category.category_name or 'unknown'
                confidence = best_category.score or 0.0
                # Color-coded boxes based on confidence levels
                if confidence >= 0.7:
                    color = (0, 255, 0)  # Green for high confidence (RGB)
                elif confidence >= 0.5:
                    color = (255, 255, 0)  # Yellow for medium confidence (RGB)
                else:
                    color = (255, 0, 0)  # Red for low confidence (RGB)
                # Draw bounding box rectangle
                cv2.rectangle(annotated_image, (x_min, y_min), (x_max, y_max), color, 2)
                # Prepare label text with confidence percentage
                confidence_percent = int(confidence * 100)
                label = f"{class_name}: {confidence_percent}%"
                # Calculate text size for background rectangle
                font = cv2.FONT_HERSHEY_SIMPLEX
                font_scale = 0.6
                thickness = 2
                (text_width, text_height), baseline = cv2.getTextSize(label, font, font_scale, thickness)
                # Position text above bounding box, or below if not...
  • Optimizing Object Detection Pipeline Performance: A 68.7% Improvement Through Systematic Bottleneck Analysis
    Vipin M • 08/11/2025 at 01:44 • 0 comments
    Introduction
    I recently completed a comprehensive performance optimization project for a ROS 2-based object detection pipeline using MediaPipe and OpenCV. The system processes camera frames for real-time object detection in robotics applications, but initial performance analysis revealed significant bottlenecks that were limiting throughput and consuming excessive CPU resources.
    The object detection pipeline consists of three main stages:
    • Preprocessing: Camera frame format conversion (BGR→RGB) for MediaPipe compatibility
    • MediaPipe Inference: Object detection using TensorFlow Lite models
    • Postprocessing: Result conversion and ROS message publishing, including optional annotated image generation
    Through systematic measurement and targeted optimization, I achieved a 68.7% reduction in total pipeline processing time, from 8.65ms to 2.71ms per frame, while maintaining full functionality and improving system stability.
    Baseline Performance Analysis
    Measurement Infrastructure
    Before implementing any optimizations, I established a comprehensive performance measurement system to ensure accurate, statistically reliable data collection. The measurement infrastructure includes:
    PipelineTimer Class: High-precision timing using time.perf_counter() for microsecond-level accuracy:
    class PipelineTimer:
        def __init__(self):
            self.stage_times = {}
            self.start_time = None
        def start_stage(self, stage_name: str):
            self.stage_times[stage_name] = time.perf_counter()
        def end_stage(self, stage_name: str) -> float:
            if stage_name in self.stage_times:
                duration = time.perf_counter() - self.stage_times[stage_name]
                return duration * 1000  # Convert to milliseconds
            return 0.0
     PerformanceStats Class: Aggregates timing data over 5-second periods and publishes metrics to ROS topics:
    class PerformanceStats:
        def __init__(self):
            self.period_start_time = time.perf_counter()
            self.frames_processed = 0
            self.total_preprocessing_time = 0.0
            self.total_mediapipe_time = 0.0
            self.total_postprocessing_time = 0.0
            self.period_duration = 5.0  # seconds
    Statistical Methodology: I used 30-second test periods with multiple measurement intervals to ensure statistical confidence. Each test collected 5-6 data points, allowing calculation of mean performance metrics and variance analysis.
    Baseline Performance Results
    Using YUYV camera format with full annotated image processing enabled, the baseline performance measurements revealed:
    >td ###Total Pipeline Time
    MetricAverage Time
    8.65ms100>#/td###
    Preprocessing Time1.22ms14>#/td###
    MediaPipe Inference2.13ms25>#/td###
    Postprocessing Time5.30ms61>#/td###
    Effective FPS2.28-
    The baseline analysis immediately identified postprocessing as the primary bottleneck, consuming 61% of total pipeline time. This stage includes MediaPipe result conversion, RGB→BGR color conversion, and ROS Image message creation for annotated output.
    Optimization #1: Conditional Annotated Image Processing
    Problem Analysis
    The postprocessing bottleneck was caused by unconditional generation of annotated images, even when no ROS subscribers were listening to the /vision/objects/annotated topic. This resulted in expensive memory operations and color conversions being performed unnecessarily.
    Implementation
    I implemented a subscriber count check to conditionally skip annotated image processing when no subscribers are present:
    def publish_results(self, results: Dict, timestamp: float) -> None:
        """Publish object detection results and optionally annotated images."""
        try:
            # Always publish detection results
            msg = MessageConverter.detection_results_to_ros(results, timestamp)
            self.detections_publisher.publish(msg)
            # Conditional annotated image publishing
            if (self.annotated_image_publisher is not None and
                'output_image' in results and
                results['output_image'] is not None):
                # Optimization: Skip expensive postprocessing if no subscribers
                subscriber_count = self.annotated_image_publisher.get_subscription_count()
                if subscriber_count == 0:
     self.log_buffered_event(
  • Refactoring Buffered Logging in ROS 2 Vision Pipelines
    Vipin M • 08/10/2025 at 20:51 • 0 comments
    When building real-time computer vision systems with ROS 2, diagnostic logging becomes critical for debugging complex processing pipelines. However, poorly designed logging systems can create more confusion than clarity. I recently refactored the buffered logging system in my GestureBot object detection node, transforming a confusing, duplicated implementation into a clean, reusable architecture that other robotics developers can learn from.
    The Problem: Misleading Abstractions and Technical Debt
    The original buffered logging system suffered from several fundamental issues that made it difficult to use and maintain:
    Confusing Terminology: The system used "production mode" and "debug mode" labels that didn't reflect actual behavior. "Production mode" suggested it was only for deployment, while "debug mode" implied it was only for development. In reality, both modes had legitimate use cases across different scenarios.
    Inconsistent Timer Behavior: The system used a 120-second timer for "debug mode" and a 10-second timer for "production mode." This inconsistency made it difficult to predict when diagnostic information would be available.
    Code Duplication: The BufferedLogger class was implemented directly in
    object_detection_node.py
    , making it impossible for other vision nodes (gesture detection, face detection) to reuse the same logging infrastructure.
    Unclear Parameters: Launch file parameters like enable_debug_buffer obscured what the system actually did, requiring developers to read implementation details to understand behavior.
    Solution Architecture: Behavior-Based Design
    I redesigned the system around three core principles: clear behavioral naming, consistent timing, and reusable architecture.
    1. Renamed Modes to Reflect Actual Behavior
    The new system uses descriptive names that immediately communicate what each mode does:
    # Before: Confusing mode names
    'mode': 'debug' if self.debug_mode else 'production'
    # After: Behavior-based naming
    'mode': 'unlimited' if self.unlimited_mode else 'circular'
    Circular Mode: Uses a fixed-size circular buffer (200 entries) with automatic dropping when full. Ideal for continuous monitoring with bounded memory usage.
    Unlimited Mode: Allows unlimited buffer growth with timer-only flushing. Perfect for comprehensive diagnostic sessions where you need complete event history.
    Disabled Mode: No buffering overhead, only critical errors logged directly. Optimal for production deployments where performance is paramount.
    2. Standardized Timer Intervals
    I unified the timer interval to 10 seconds across all modes, eliminating the arbitrary distinction between 120-second and 10-second intervals:
    # Before: Inconsistent timing
    flush_interval = 120.0 if enable_debug_buffer else 10.0
    # After: Consistent 10-second intervals
    self.buffer_flush_timer = self.create_timer(10.0, self._flush_buffered_logger)
    This change provides more responsive feedback while maintaining reasonable performance characteristics.
    3. Moved to Base Class Architecture
    The most significant architectural improvement was moving BufferedLogger from the specific object detection node to the base MediaPipeBaseNode class:
    # vision_core/base_node.py
    class MediaPipeBaseNode(Node, ABC):
        def __init__(self, node_name: str, feature_name: str, config: ProcessingConfig,
                     enable_buffered_logging: bool = True, unlimited_buffer_mode: bool = False):
            super().__init__(node_name)
            # Initialize buffered logging for all MediaPipe nodes
            self.buffered_logger = BufferedLogger(
                buffer_size=200,
                logger=self.get_logger(),
                unlimited_mode=unlimited_buffer_mode,
                enabled=enable_buffered_logging
     This inheritance-based approach means any new vision node automatically gains sophisticated logging capabilities without code duplication.
    4. Updated Launch File Parameters
    The launch file parameters now clearly communicate their purpose:
    # Before: Unclear parameter names
    declare_enable_debug_buffer = DeclareLaunchArgument(
        'enable_debug_buffer',
     default_value=...
  • Simplifying MediaPipe Vision Processing
    Vipin M • 08/10/2025 at 20:46 • 0 comments
    In my recent work on the GestureBot vision system, I made several architectural improvements that significantly simplified the codebase while maintaining performance. Here's what I learned about building robust MediaPipe-based vision pipelines in ROS 2.
    The Problem: Over-Engineering for Simplicity
    Initially, I implemented a complex architecture with ComposableNodes, thread pools, and async processing patterns. The system created a new thread for every camera frame and used intricate callback checking mechanisms. While this seemed like a performance optimization, it introduced unnecessary complexity:
    # Old approach - complex threading
    threading.Thread(
        target=self._process_frame_async,
        args=(cv_image, timestamp),
        daemon=True
    ).start()
    # Complex callback checking after submission
    if self.processing_lock.acquire(blocking=False):
        # Process and check callback results...
     I refactored the entire system to use a straightforward synchronous approach that separates concerns cleanly:
    1. Converted from ComposableNode to Regular Node Architecture
    Before:
    camera_container = ComposableNodeContainer(
        name='object_detection_camera_container',
        package='rclcpp_components',
        executable='component_container',
        composable_node_descriptions=[
            ComposableNode(package='camera_ros', plugin='camera::CameraNode')
    After:
    camera_node = Node(
        executable='camera_node',
        name='camera_node',
        namespace='camera'
    Why this works better: Since my object detection node runs in Python and can't be part of the same composable container anyway, using regular nodes eliminates complexity without sacrificing performance.
    2. Separated Processing Contexts
    I redesigned the processing flow to have two distinct, non-blocking contexts:
    def image_callback(self, msg: Image) -> None:
        """Simple synchronous image processing callback."""
        cv_image = self.cv_bridge.imgmsg_to_cv2(msg, 'bgr8')
        timestamp = time.time()
        # Process frame synchronously - no threading complexity
        results = self.process_frame(cv_image, timestamp)
        if results is not None:
            self.publish_results(results, timestamp)
     Key insight: Instead of checking MediaPipe callbacks after submission, I let MediaPipe's callback system handle result publishing directly. This eliminates the need for complex synchronization between submission and result retrieval.
    3. Fixed MediaPipe Message Conversion Robustness
    MediaPipe sometimes returns None values for bounding box coordinates and confidence scores. I added comprehensive None-value handling:
    # Handle None values explicitly
    origin_x = getattr(bbox, 'origin_x', None)
    msg.bbox_x = int(origin_x) if origin_x is not None else 0
    # Robust confidence assignment with multiple fallback approaches
    if score_val is not None:
        confidence_val = float(score_val)
    else:
        confidence_val = 0.0
    try:
        msg.confidence = confidence_val
    except:
        object.__setattr__(msg, 'confidence', confidence_val)
    This eliminated the persistent <function DetectedObject.confidence at 0x...> returned a result with an exception set errors that were blocking the system.
    4. Added Shared Memory Transport for Performance
    While simplifying the architecture, I maintained performance by enabling shared memory transport. This provides most of the performance benefits of ComposableNodes without the architectural complexity.
    5. Cleaned Up Topic Namespace
    I consolidated all camera-related topics under a clean /camera/ namespace:
    remappings=[
        ('~/image_raw', '/camera/image_raw'),
        ('~/camera_info', '/camera/camera_info'),
     This eliminates duplicate topics like /camera_node/image_raw and /camera/image_raw that were causing confusion.
    Results: Better Performance Through Simplicity
    The refactored system achieves:
    • Eliminated threading overhead: No more thread creation per frame
    • Cleaner error handling: Robust None-value processing prevents crashes
    • Simplified debugging: Linear execution flow is easy to trace
    • Maintained performance: Shared memory transport...
  • Mechanical Design and Hardware Integration Notes
    Vipin M • 08/08/2025 at 17:43 • 0 comments
    Hardware Platform
    • Base: iRobot Create 2 (Roomba)
    • Structural frame: 3/4" Schedule 40 PVC pipe
    • Custom parts: 3D‑printed base bracket and upper “blue” electronics enclosure
    • Sensors and compute (upper assembly): Raspberry Pi 5 + active cooler, camera, MPU6050 IMU, top‑mounted LiDAR, 3S LiPo, 5 V regulator, wiring harnesses
    Why iRobot Create 2 (Roomba) as the base
    I chose the Create 2 because:
    • It is a proven, rugged differential‑drive platform with integrated motor drivers, encoders, bump sensors, cliff sensors, and a charge dock interface.
    • The Open Interface (OI) provides documented serial control for motion and telemetry, which simplifies bring‑up and reduces the number of custom PCBs I need to maintain.
    • The chassis carries batteries low in the body, giving a naturally low center of mass that helps with the tall mast structure.
    • Replacement parts and batteries are widely available; consumables (wheels, brushes) are inexpensive.
    In short, it gives me reliable locomotion and power infrastructure so I can focus engineering time on perception and interaction.
    Structural Framework: 3/4" Schedule 40 PVC
    I built the superstructure as a four‑post mast using standard 3/4" Schedule 40 PVC with printed sockets at the base and a printed upper enclosure that captures the posts.
    PVC framework rationale
    • Cost‑effectiveness: PVC pipe and fittings cost a fraction of aluminum extrusion and require no specialty tooling. I can build and iterate for a few dollars per meter.
    • Structural rigidity: For a ~1–1.2 m mast, four 3/4" PVC uprights provide adequate bending stiffness when posts are constrained at both ends; adding a single mid‑height brace eliminates noticeable sway.
    • Lightweight: Low mass keeps the center of gravity near the Roomba deck, improving tip resistance during sudden stops or dock approaches.
    • Modularity: I cut posts to length and swap elbows/tees to reconfigure sensor height in minutes. Printed collars give me mounting points exactly where I need them.
    • Easy iteration: I can drill, ream, and solvent‑bond or simply screw into PVC without worrying about galvanic corrosion or thread wear in thin‑wall aluminum.
    Practical tip: I lightly ream the pipe OD and size printed sockets with +0.3 to +0.5 mm clearance, then use two self‑tapping screws per joint. This holds under vibration and still allows disassembly.
    Base Bracket (3D‑printed)
    The base bracket is a circular plate that sits on the Roomba’s top deck and presents four vertical sockets for the PVC posts.
    Design choices:
    • I align the sockets on a square bolt circle to match the upper enclosure’s posts; this prevents torsion and keeps the mast square.
    • The bracket uses the Create 2’s existing screw bosses for anchoring (no drilling in the shell). I embed heat‑set inserts in the print so I can torque fasteners without crushing plastic.
    • Filleted ribs radiate from each socket into the center ring to distribute mast loads and survive side hits.
    Material and print settings:
    • PETG or ABS at 30–40% gyroid infill, four perimeters, 0.24–0.28 mm layer height. PETG gives enough ductility to absorb bumps without cracking.
    Upper Assembly (“Blue Enclosure”)
    The upper enclosure is a printed housing that integrates compute, power, and sensors while acting as the frame’s top plate. It also provides an easy surface for future sensors and user interfaces.
    What I integrated
    • Raspberry Pi 5 (8 GB) with the official active cooler
    • 5 V buck regulator (≥ 5 A) from the 3S LiPo rail
    • IMX219 camera module (front‑facing), recessed window
    • MPU6050 IMU (mounted near the enclosure’s CG to reduce rotational noise)
    • Top‑mounted LiDAR (clear 360° FOV, minimal occlusion from the mast)
    • 3‑cell LiPo battery with inline fuse and master switch
    • Cable glands and internal harnesses
    Thermal management
    • I treated the Pi 5 cooler as a forced‑air inlet and provided exhaust vents on the opposite wall. Short, straight flow paths are more effective than decorative perforations.
    • Mounting bosses...
View all 14 project logs
