The Candle Flame Oscillator
A project log for Deriving 1 Hz from Candle Flame Oscillations
Using capacitive sensing to measure the oscillation of a candle flame and converting it to a 1 Hz clock
timTim • 08/12/2025 at 07:51•2 Comments
So, what happens with our bundle of three candles? It will basically undo millennia of candle technology optimization to avoid candle flicker. If left alone in motionless air, the flames will suddenly start to rapidly change their height and begin to flicker. The image below shows two states in that cycle.
Two states of the oscillation cycle in bundled candles
We can also record the brightness variation over time to understand this process better. In this case, I used a high-resolution ambient light sensor to sample the flicker over time. (This was part of more comprehensive experiments I conducted a while ago, which I'll write up in detail eventually.)
Plotting the brightness evolution over time shows that the oscillations are surprisingly stable, as shown in the image below. We can see a very nice sawtooth-like signal: the flame slowly grows larger until it collapses and the cycle begins anew.
On the right side of the image, you can see the power spectral density plot of the brightness signal on the left. The oscillation is remarkably stable at a frequency of 9.9 Hz.
Left: Brightness variation over time showing sawtooth pattern. Right: Power spectral density showing stable 9.9 Hz frequency
This is very curious. Wouldn't you expect more chaotic behavior, considering that everything else about flames seems so random?
The phenomenon of flame oscillations has baffled researchers for a long time. Curiously, they found that the oscillation frequency of a candle flame (or rather a "wick-stabilized buoyant diffusion flame") depends mainly on just two variables: gravity and the dimension of the fuel source. A comprehensive review can be found in [3].
Now that is interesting: gravity is rather constant (on Earth) and the dimensions of the fuel source are defined by the size (diameter) of the candles and possibly their proximity.
This leaves us with a fairly stable source of oscillation, or timing, at approximately 10Hz.
There was this 1 Hz competition? So, why don't we use our flame oscillator reference to generate a 1 Hz clock signal?
[3] J. Xia and P. Zhang, "Flickering of buoyant diffusion flames," Combustion Science and Technology, 2018.
Paul McClay wrote 08/17/2025 at 08:32 • point
Very curious indeed!
The compliment of lava lamps for randomness. :)
Tim wrote 08/17/2025 at 08:49 • point
Hehe, indeed. The opposite of randomness. Did not think about it that way.
