Features
- A retro-style dot matrix display:
- 17x6 5mm LED matrix
- Different LED colors for main area, status bar and number separator
- No flickering, ghosting or uneven brightness
- High refresh rate of 460Hz
- 8-bit global brightness and 3-bit per-pixel brightness
- Global brightness is automatically (and smoothly) adjusted by ambient conditions, just like on your phone!
- Accurate timekeeping:
- Temperature-compensated crystal clock (DS3231SN chip)
- Backup power to keep the clock ticking (CR2032 battery)
- Displays minute, hour, day, weekday, month, year and even ambient temperature
- Green status bar tracks seconds (incremented every 4s)
- Five alarms with melody
- Intuitive (kinda) user interface with three buttons
- Cool acrylic glass frame
- Powered by any USB brick through a Type-B cable
- Finally, a reason to pick that old printer cable from your drawer!
- Built around ATmega32 microcontroller, with firmware written in C++
- Uses every I/O pin on ATmega32, no wasted potential!
- No AI and no internet connection! (yup, that's a feature nowadays...)
- Totally open-source!
Downloads and build instructions
You can find the latest project files on the project Github page
Silica Gel
Lexcis
Camilo Alvarez
Xed89
pauliusbau
