The BT840XE XBEE-Compatible Expansion Board is designed as a seamless upgrade for any device using the XBEE footprint. It integrates the powerful BT840XE module, offering multi-protocol wireless communication while keeping pin compatibility with existing designs.
Ideal for IoT developers, industrial automation, sensor networks, and long-range telemetry.
Key Highlights:
Fully XBEE footprint-compatible (plug-and-play upgrade)
Bluetooth 5 and Zigbee support
Industrial-grade RF performance with U.FL or chip antenna options
Wide temperature range: -40°C to +85°C
Multiple interfaces: UART, SPI, I²C, GPIO, RESET, SWD
Ready for development and production
Files
DI-EpeirIOTDVBT84001-001.pdf
Datasheet
Adobe Portable Document Format -
531.83 kB -
08/14/2025 at 23:53
