• Prototype #3
    dylan.elliott08/14/2014 at 20:54 0 comments
    I got my fabricated PCB back from Fritzing and, luckily, I had all the parts to build it right away. It was all pretty straight forward.
    I learned that the Tiny has to have the 8MHz, no internal oscillator boot loader burned too it (That was a bit of a waste of time).
    I think I need to rearrange the PCB so it faces the correct way when plugged into a computer.
    Other than that, everything is going smoothly. The next things to do are to design a case (Of course I'll 3d print it) and to get a simpler interface for adding commands.
