Formula 1 info tracker
ESP32 desktop Formula 1 stats tracker
Here is my F1 info tracker based on esp32 and 2.9 tri-color e-paper display. Originally made for my son as a desk gadget. Project uses ergast API to get race and points information and it is parsed using json library. Webserver dashboard is also available once device is connected to WiFi. Tracker refreshes data every 30 minutes or at every reboot. link to project is here: https://github.com/mazur888/F1-Info-display
more info and details on github here: https://github.com/mazur888/F1-Info-display
this includes 3D STL files, pictures and more!
using USB-C to C cable:
Solder optional 5k1 resistors between CC1 and GND, and CC2 and GND to enable USB-C to USB-C cables. without them only USB-A to USB-C will work.
2.9 v2 base.stl
No supports needed
Standard Tesselated Geometry - 52.13 kB - 10/02/2025 at 21:05
Download
2.9 v2 front.stl
No supports needed
Standard Tesselated Geometry - 64.14 kB - 10/02/2025 at 21:05
Download
2.9 v2 back plate.stl
No supports needed
Standard Tesselated Geometry - 51.84 kB - 10/02/2025 at 21:05
Download
2.9 v2 base cap.stl
No supports needed
Standard Tesselated Geometry - 3.01 kB - 10/02/2025 at 21:05
Download
  • 1 × esp32 LOLIN D32 dev board
  • 1 × WeAct 2.9'' 3 color e-paper display https://www.aliexpress.com/item/1005004644515880.html?spm=a2g0o.order_list.order_list_main.11.616e1802B1wa4k
  • 1 × USB-C socket https://www.aliexpress.com/item/1005007144793925.html?spm=a2g0o.order_list.order_list_main.17.43ef1802xEeWzX
  • 2 × (optional) 5k1 resistors Solder them between CC1 and GND, and CC2 andGND to enable USB_C to USB-C cables. without them only USB-A to USB-C will work
View project log
kaoswarner wrote 06/13/2026 at 01:40 point
I've gotten everything and the soldering done but i cannot find for love nor money the memory address for the partition and platform files when doing the flashing. Should I leave them to default 8 and 10?
