The ultra low power LED project by Christoph Tack improved upon Ted Yapo's TritiLED with the following banner spec:
1.36µA on a 3V power supply (1 LED, 3µs pulse width, 64Hz repetition rate).
I don't think that I can improve on these raw numbers much, but there are some details that can be improved:
- instead of an exotic RTC chip which is really overkill, build an ultra-low power oscillator out of jelly-bean transistors and some passives - by Dave Johnson at DiscoverCircuits.com
- increase the pulse length as the battery voltage drops to maintain LED current.
- use a smaller inductor - a huge 12mm×12mm power inductor really isn't necessary
Stephan Walter
Christoph Tack
Nicholas Amrich
Elliot Williams
Very good! I simulated your oscillator in LTSpice and got about 91nA(rms), 52nA(average).
I have my doubt about the 100M resistors. What about leakage, PCB-dirt etc?
