The nrf dongle has many stones on its hacking path.
- UICR.REGOUT has to be set to 3v3
Default to do so might brick it, and rescue needs high voltage jumpers switch explanation from Nordic here
- UICR.NFCPINS
Using the simplest pio, with my luck on falling over pio 0.10, of course it does not work, you need to set the UICR of NFCPINS PROTECT to disable.
- LEDS don't blink
although defined with the right functions LED1_G,... into pca10059.h, when using
bsp_board_led_on() indexes from 0 to nb leds have to be passed and not the led defines !!!
- Ground mass
without a bigger ground mass, the cpu keeps getting hard faults, so when debugging with swd I had to connect a usb charger without powering it on, just for bigger ground mass.
