Hello Mesh - RGB Colors Broadcast
A project log for Home Smart Mesh
Mesh of sensors, zigbee, custom RF, BT, wifi, all to MQTT Gateways on Raspberry Pi with database, dashboard and webapps.
WassimWassim 03/22/2017 at 19:217 Comments
Demo
This was the very first step in this project that shows how machines talk to each other in a way humans could perceive :
Firmware
WS2812B bitbanging
void rgb_SendArray()
    BYTE int_state = __get_interrupt_state();
    __disable_interrupt();
  asm(
        "lb_intiLoop:                          \n"
        "LDW      X,             #0xFFFF       \n"// set -1 in X, so that first inc gets 0, as inc has to be in the beginning of the loop
        "LDW      Y,             L:nbLedsBytes \n"//2
        "lb_begin_loop:                        \n"
//--------------- bit 0 -----------------------------------------
        "INCW    X                           \n"// L t+2
        "lb_start_bit0:                      \n"//
        "LD      A,           (L:LedsArray,X)\n"//
        RGBLedPin_Set
        "AND     A,             #0x80        \n"// H t2
        "JREQ    L:lb_bit0_Send_0            \n"// H0 t3 t4 : 2 jump to Zero, 1 Stay in One + next nop
        "lb_bit0_Send_1:                     \n"//------Send 1 : 800ns High, 450ns Low (12,8) 750ns,500ns
        "nop                                 \n"// H1 t5
        "nop                                 \n"// H1 t6
        "nop                                 \n"// H1 t7
        "nop                                 \n"// H1 t8
        "nop                                 \n"// H1 t9
        "nop                                 \n"// H1 t10
        "nop                                 \n"// H1 t11
        "nop                                 \n"// H1 t12
        RGBLedPin_ReSet                         // L1 t1
        "nop                                 \n"// L1 t2
        "JRA     L:lb_start_bit1             \n"// L1 JRA:2 t4
                                                // L1 NextBitTest:4  t8
        "lb_bit0_Send_0:                     \n"//------Send 0 : 400ns High, 850ns Low (7,13) 375ns,875ns
                                                // H0 t4
        RGBLedPin_ReSet                         // L0 t1
        "nop                                 \n"// L0 t1
        "nop                                 \n"// L0 t2
Full source code part of the STM8S driver : github IoT_Frameworks WS2812B.c
Color Flashing
void rgb_FlashColors(BYTE delay, RGBColor_t Color)
  for(int iCount=0;iCount<255;iCount++)//0-10
    RGBColor_t Ci = rgb_ColorScale(iCount,255,BLACK,Color);
    rgb_SendColors(Ci);
    delay_ms(delay);
    RGBColor_t Ci = rgb_ColorScale(iCount,255,Color,BLACK);
    rgb_SendColors(Ci);
    delay_ms(delay);
  rgb_SwitchOff();
RF Broadcast
Voltage levels
avtop2k wrote 02/26/2019 at 16:23 point
please share circuit diagram of STM8S rf node and STM8L mobile Node
thx
Wassim wrote 02/26/2019 at 18:45 point
The PCB design in eagle are already shared in this github repo : https://github.com/HomeSmartMesh/STM8_IoT_Boards/tree/master/IoT_Node_Mobile_v2
Wassim wrote 02/26/2019 at 18:47 point
Here is the latest generation that I recommend more powerful than the STM8 https://github.com/nRFMesh/nRF52_Mesh
avtop2k wrote 02/26/2019 at 16:16 point
https://github.com/HomeSmartMesh/IoT_STM8  Is rdb_leds project using  mash network mode ? I am not able understand  how its work like how 1st receive code for 2nd node that client of 1 st node
thx
Avtar
Wassim wrote 02/26/2019 at 18:08 point
Hi, see the protocol in https://www.homesmartmesh.com/mesh/
byte2 is source id, the node that sent the packet, and byte3 is dest, the node that shall use the packet, other nodes that receive the same message but have different id shall ignore the packet.
Please note that the IoT_STM8 is no longer maintained, the currently supported platform is the the nRF52840.
Let me know if you have more questions.
avtop2k wrote 07/04/2018 at 18:08 point
Hi
I trying to compile rgb_leds but in libs error rfi_header_size,rf_pid_0xDF_retransmit and rfi_payload_offset is undefined ,How to compile
Wassim wrote 07/04/2018 at 18:50 point
Hi, I spotted some duplications of the same comment :)
Hi, yes, thank you for your finding, I fixed these compilation errors in the commit I made today just for maintenance
541ae723d424edbea4a077d8590023a95d9712cb
make sure you're using the repo https://github.com/HomeSmartMesh/IoT_STM8
But actually, the STM8 was the very first version of the mesh HW and I stopped working with it, that is why they are deprecated, and at the time, I did not had a good project share with submodules to prevent update of shared libs without breaking other projects.
Since then, I moved to the STM32 for bridges and continuously powered devices, I implemented also a driver for the WS2812B there. https://github.com/HomeSmartMesh/IoT_Frameworks/tree/master/stm32_rf_dongle/rf_bridge
And after the STM32, I switched to the nRF52 for which I found nice small USB dongles that I reflash with nRF firmware. I see you also followed my project #nRF52 Sensors Mesh Network , thank you for your interest, that is the project I am currently actively working on, so if you have questions or require support for that project I will be able to help much easier.
