Smart LED Panel - MQTT to x216 WS2812B
A project log for Home Smart Mesh
Mesh of sensors, custom, zigbee and more all to MQTT Gateways on Raspberry Pi with database, dashboard and webapps.
WassimWassim 04/29/2017 at 13:320 Comments
Demo
How is this working ?
PID - NodeID - R - G - B - CRC
MQTT Control
For convenience here, I used a ready Android application MQTT Dash which worked out of the box once I used the topic payload format for colors which is the #RRGGBB (e.g #FFFFFF for white). It is enough to program the right topic address (e.g. Nodes/10/RGB), this app is cool as it even provides colors pickers.
By the way, we can see here a TVSet Power as well which is an off the shelf Wemo switch connected through OpenHAB2 and MQTT.
Conclusion
If you need just brighter light for your room, do not use this Panel which is more valuable than that, I plan to shit it to a central messaging notifiers and use it to display text and symbols.
