A simple ESP32 and round display based eyeball with instructions for casting into epoxy half spheres.
support v2.svgBacking support plate for eye to cover the 2.5in moldsvg+xml - 5.31 kB - 08/26/2025 at 18:40 |
sticker2.svgThis is the vinyl cut pattern for the blackout sticker to cover the support frame and cover the blank space to the edge of the eye.svg+xml - 2.16 kB - 08/26/2025 at 18:37 |
mold_holding - v2.svg*optional* these are laser cut cardboard supports to hold the mold during epoxy curingsvg+xml - 10.13 kB - 08/26/2025 at 18:41 |
