The Gear You’ll Need
That power detail is important: SIM800L is picky and gulps down current spikes up to 2A when it transmits. A phone battery or proper buck converter works best, don’t expect the Pico’s 5V pin to keep it alive.
How It Works
Here’s the flow:
  1. The GPS module spits out NMEA sentences (those $GPGGA and $GPRMC strings with coordinates and time).
  2. The Pico parses that stream into something usable.
  3. The SIM800L takes those numbers and shoots them off using HTTP requests.
  4. A cloud service (CircuitDigest Cloud in this case) logs the data and shows it on a map.
And because the Pico has some extra smarts, it can also buffer data locally. If your GSM connection drops while you’re out of range, it just saves the GPS points and uploads them once you’re back online. That way you don’t end up with gaps in the trail.
The Modules
Neo-6M GPS:
SIM800L GSM:
Wiring Things Up
The Pico just coordinates everything, it doesn’t have to supply the power-hungry parts.
Talking to the Cloud
Instead of reinventing the wheel, this project leans on GeoLinker API from CircuitDigest Cloud. You sign up, grab an API key, and drop it into your Pico code. Once the tracker has that, it can post coordinates straight to the server, and you get a map interface showing where it’s been.
The nice part is you don’t have to spin up your own backend or database, it’s already set up for GPS logging.
Coding
You can do this through the Arduino IDE with the RP2040 board package installed. After that, install the GeoLinker library, which comes with examples tailored for Pico + SIM800L + GPS.
The basic code flow looks like this:
The library smooths over the nasty AT commands, so you’re mostly dealing with higher-level functions.
Testing It
Stick the whole rig near a window (GPS hates being indoors). Power it with a LiPo pack, open your CircuitDigest Cloud dashboard, and watch as points start showing up on the map. Walk around with it in your pocket and you’ll see the trail update in real time.
If things don’t work right away, common culprits are:
Wrap-Up
This Raspberry Pi Pico project is a neat way to build a low-cost, no-frills GPS tracker. It’s not a polished commercial gadget, but that’s the fun, you get to wire it, power it, and see exactly how the data makes its way from satellites → Pico → GSM → internet → your screen.
Once you’ve got it running, you could extend it: maybe log data to an SD card, add a small display, or tweak it to send alerts when it leaves a certain area. The foundation is solid, and the Pico makes it approachable without needing heavy hardware or complicated networking.
You will find the detailed step-by-step version of this project here: Raspberry Pi Pico GPS Tracker
