RP2350B-Flight-controller
Ultra-compact flight controller for mini quadcopters, based on RP2350B MCU.
Board size: 30.5 × 39.8 mm, yet includes IMU, radio module, motor drivers, and full USB power support.
Key Features
- MCU: RP2350B (dual-core, PIO, USB device)
- IMU: LSM6DS3 (accelerometer + gyroscope, SPI connection)
- Radio module: NRF24L01 + RFX2401C PA/LNA amplifier
- Motors: 4× brushed DC motors (up to 5 A per channel, short peak)
- USB-powered flight possible (low-current motors, enough supply over USB)
- Additional expansion pins (GPIO3–16 + SWD) for sensors, debugging, or add-ons
Pin Mapping
IMU (LSM6DS3) — SPI2
| RP2350B GPIO | Signal | Notes |
| GPIO19 | SPI2_MISO | Sensor data out |
| GPIO22 | SPI2_MOSI | Sensor data in |
| GPIO23 | SPI2_SCK | SPI clock |
| GPIO20 | IMU_INT1 | Interrupt 1 |
| GPIO21 | IMU_INT2 | Interrupt 2 |
Radio Module (NRF24L01 + RFX2401C)
| GPIO28 | SPI_MOSI | Shared SPI bus |
| GPIO36 | SPI_MISO | Shared SPI bus |
| GPIO37 | SPI_SCK | Shared SPI bus |
| GPIO30 | NRF_CS | Chip select |
| GPIO31 | NRF_CE | Enable |
| GPIO32 | NRF_IRQ | Interrupt |
Motors
| RP2350B GPIO | Output | Notes |
| GPIO45 | Motor_1 | Brushed motor driver |
| GPIO46 | Motor_2 | Brushed motor driver |
| GPIO47 | Motor_3 | Brushed motor driver |
| GPIO48 | Motor_4 | Brushed motor driver |
| GPIO49 | Motor_current | Current sense |
| GPIO52 | Motor_voltage | Battery/rail voltage sense |
LEDs
| GPIO17 | LED1 | Status LED |
| GPIO18 | LED2 | Status LED |
Debug / Expansion
- SWD interface exposed for programming/debugging
- GPIO3–16 free for custom extensions (I²C, UART, SPI, PWM, ADC etc.)
Power
- Powered from USB or external battery
- USB can sustain hover/low-thrust operation with small coreless motors
- Onboard regulation for MCU, IMU, radio, and motor supply
Use Case
- Designed for tiny brushed quadcopters and robotics experiments
- Combines motion sensing, wireless control, and motor drivers in one small board
- Fits into custom drone frames without extra breakout boards
Quick Start
- Connect via USB-C for firmware flashing and testing.
- Flash firmware (e.g. custom flight stack on RP2350B).
- Connect brushed motors to outputs GPIO45–48.
- Pair radio link via NRF24L01 (with RFX2401C amp).
- Power from USB for tests, or from LiPo for flight.
Notes
- Motor channels rated for 5 A peak per motor (coreless brushed).
- Ensure airflow for heat dissipation at higher loads.
- Expansion pins allow integration of GPS, barometer, or additional sensors.
Vitaly Kornilov
Ghani Lawal
YJ
Keith
XorTech.Electronics
