Screen Design
The 19 inch CRT inside the Type 30 was used primarily for radar screens. Not many of those kicking around any more or for that matter CRTs of any size. While there are a number of round LCD screens available today they come in two flavors, small and relatively cheap, or large and prohibitively expensive. So finding a round screen for this project is probably not an option. That leaves trying to fit a square screen into a round opening. Since I knew that this would be the key to making a good reproduction I put some work into the design.
From the Precision CRT Display / Type 30 Manual the following page provides some key information towards a design.
From the first paragraph we learn that:
- the screen opening is 16" in diameter,
- that the screen resolution is 1024 x 1024 pixels,
- and that the active area of the screen is 9.5 inches square.
Knowing that the circular opening is 16" helped me to scale my model properly. By bringing in a photo of the Type 30 as a "background" Canvas to Fusion I was able to calibrate the image to proper mm coordinates (sorry I'm Canadian). Since I am doing a 2:3 scale model the screen opening becomes 270 mm in diameter. With that as a starting point I roughed out the front face of the Type 30 in Fusion.
Outside hexagonal lines define the walls of the monitor. The inside most hexagon and the imbedded circle make up the mask that sits in front of the "CRT tube". Nested in the circle the dotted square marks the active 9.5 x 9.5 inch area of the screen in the original (or in my case 160 x 160 mm at 2:3 scale). The other two solid rectangles represent the outside and screen dimensions of a 10-inch LCD Screen Kit (1024x768) that I found. Since it's a 4:3 screen the fit is almost perfect for this project.
So here is the plan.
The Front Face is a stack (left above) made up of the following layers numbered from top to bottom.
- Screen mask that frames the "CRT display".
- A "filter" that is opaque enough to hide the fact that there is a rectangular screen imbedded in the next layer but translucent enough so that the screen below can be seen through when active.
- Frame to secure the LCD panel. The panel surface will be flush with the top of the frame so that it comes in contact with the filter layer above it.
- An LCD screen.
- The Type 30 case (shown in part here).
On the right above an "assembled" screen.
With this in hand I'm comfortable enough to order the LCD panel. While I wait for that I'll get the PiPD-1 software going.
This is going to be fun.
Michael Gardi
Valrum
Mike Szczys
ogdento
Very inspiring. Looks awesome!
