How to use ESP32 in your Projects?
Projects which are using ESP32 microcontroller
Are you an ESP32 lover? Then you are at the right place. 1. Drone: Use an ESP32 as the flight controller, paired with an IMU sensor (BNO055) and motors. The control can be managed via Wi-Fi using a web app, with custom-designed PCB frame for lightweight construction. https://youtu.be/esmYcBHqBK8?si=HybdpV2Q2QWrL7N0 2. RC Car: The ESP32 acts as the main controller for a RC car with DC motors. A motor driver board (L298N) is for controlling the motor's speed and direction. It can be controlled wirelessly by using a web interface. 3. Solar Charger: The ESP32 can be used to create a smart power system. It requires a solar panel, a battery, and a charging module (TP4056) to regulate power. A voltage regulator is also needed to supply the voltage to the ESP32. This system can be programmed to monitor battery levels and solar panel output. 4. RC Paper Airplane with ESP32 and FPV camera: https://youtu.be/hDjBi0ErDdw
Github: https://github.com/sPyOpenSource/ESP32-PCB
Patreon: https://www.patreon.com/posts/39694951?collection=163072
mscThesis.pdf
paper
Adobe Portable Document Format - 3.73 MB - 09/12/2025 at 08:37
Preview
  • 1 × ESP32 controller board
  • 4 × motors
  • 1 × LiPo battery
  • 1 × frame
  • 4 × propellers
  • Paper Airplane
    X. Wang02/21/2026 at 07:32 0 comments
    We can use a smartphone to controlled a FPV RC paper airplane powered by an ESP32 microcontroller and a micro-MOSFET driver. It integrates a camera for live video and uses the ESP32 sensors for stabilization.
View project log
