Firmware Emulation in the Browser Using WASM
A project log for Home Plant Watering System Based on the PIC10F202
A home plant watering device based on a simple 8-pin PIC microcontroller and 74HC chips.
robert-gawronRobert Gawron 03/08/2026 at 16:130 Comments
I've built a version of my C firmware that runs in the browser. I stubbed the hardware peripherals using JavaScript, I can run, test, and validate high-level logic directly in the browser without needing to flash the real device.
This approach has several benefits:
The simulation setup includes:
You can check the source code on project's GitHub.
Ultimately, WASM is quite an interesting technology!
