Premium Audio Player
A HTML based Premium Audio Player with Audio effects you don't get on other players for high quality audio
A premium HTML based Audio Player with extra effects like stereo wide. Supports all of the standard audio formats. Proper effects like Stereo Wide, Compressor to bring sound levels up and an Exciter DSP effect to add harmonics into the audio for higher frequencies. All rendered into a glassy look with a high end look and feel. Why HTML based ? Because I wanted this player to be OS agnostic, Just open in your web browser supports high quality flac files and visually shows to the user when in high quality mode
premium-Audio-PlayerV1-1.zip
updated so the high quality mode is visible if the user loads a high quality flac song. also the spectrum analyser updates for wider bandwidth up to 48khz if a high quality flac file is loaded. just unzip this file and open the html file
Zip Archive - 17.65 kB - 07/21/2026 at 21:46
Download
