A compact switching power supply designed for test automation and HIL setups.
Powered from USB-C PD (100 W)
Controlled via USB with a clean Python library
Built with Open Source Hardware & Software principles
Our goal is to create a new category of instruments: affordable, open, and designed specifically for testing.
Features
Output: 0–32 V / up to 3 A (96 W max)
Ripple: < 30 mVpp, < 2 mA RMS
Protections: OVP, OCP, OPP, OTP
Measurement resolution: 10 mV / 1 mA
Control: USB-B (SCPI, custom firmware mods), PLD connector for extensions
Expandability: LEDs for status, button for manual toggle, optional module with screen/knobs
Technical Specs
Electrical Parameters
| № | Parameter | Value |
| 1 | Input | USB Type-C Power Delivery 100W |
| 2 | Output | Not galvanically isolated |
| 3 | Number of channels | 1 |
| 4 | Max output power | 96 W |
| 5 | Output voltage | 0–32 V |
| 6 | Output current | 3 A max |
| 9 | Voltage ripple | < 30 mVpp |
| 10 | Current ripple | < 2 mA RMS |
| 11 | Load regulation (10–90%) | ±0.1% + 20 mV / ±0.1% + 5 mA |
| 14 | Load recovery time | < 200 µs |
| 15 | Line regulation (±10%) | ±0.1% + 20 mV / ±0.1% + 5 mA |
| 18 | Voltage overshoot (turn-off) | < 100 mV |
| 20 | Setpoint resolution | 10 mV / 1 mA |
| 23 | Setpoint accuracy | ±0.1% + 30 mV / ±0.1% + 5 mA |
Measurements
Quantities: Voltage, Current, Power
Accuracy: ±0.1% + 30 mV / ±0.1% + 5 mA
Resolution: 10 mV / 1 mA
Protections
Overvoltage (OVP) — configurable
Overcurrent (OCP) — configurable, trip < 10 ms at 2× load
Overpower (OPP) — configurable
Overtemperature (OTP)
Structure
- USB Host - control device (PC, single-board computer, laptop, etc.),
- DUT - load, device under test
- Type C Adapter - any USB-C power source, e.g., mains, power bank, laptop, phone.
- The MCU controls all parts of the unit. This makes it possible not only to control the source from a PC, but also to load presets according to a predefined algorithm and link the power supply to external events.
- PLD connector - a universal connector that provides input and output power, USB control, microcontroller interfaces, and logic power.
Of course, this is a specialized power supply, and we do not intend to replace laboratory power supplies. Let's talk more about the application options.
Use Cases
In Test Stands
Automated cycling, no manual knobs or displays
Board-to-board or internal wiring power delivery
Multiple modules for multi-voltage DUTs
PC inside the fixture, USB control via PLD
On the Desk
Simple power setup for developers
Configured via console, Jupyter, or SmuView
One button, LED indicators, optional expansion with knobs & screen
Roadmap
- Collect feedback from the community
- Build and test prototypes
- Crowdfunding launch on CrowdSupply
N. Series of compact open tools: USB HUB, multimeter, production programmer, signal MUX, logic analyzer, DAQ...
Ioan Larionov
Andy
Arshmah Shahkar
Interesting idea! Do you have any BOM cost goals or thoughts yet?
