Goals
Test software is ready. Time to test the test software!
Features to test:
- STM32 PD controls the voltage from the Type-C power supply
- 2 channels of the STM32 DAC are controlled in the terminal
Why did I choose them? Regulation of Vout and average current - the biggest risk at the moment. PD is needed to test the power supply EVM with real Type-C inputs.
Scheme
Simple connection of two devboards from ST and a power adapter.
Test
For power delivery, there is a ready solution from ST. On the PC side using Stm32CubeMonitor UCPD. Manipulating voltage through the GUI is straightforward.
The only moment was inconvenient - UCPD utilises Nucleo's USB-VCP only when the built-in ST-LINK is reconfigured to VCP + debug. In the default state (Drive+VCP+Debug), they don't work together.
Results
- 2 DACs are controlled through the terminal, but are twisted and
- Can request USB PD supply with profiles:
- 5V 1.5A
- 9V 3A
- 20V 3A
Ready to power up LM51772EVM!
Ioan Larionov
