Mockup #1 - Opamp board
A project log for Powerblock 323
Reliable power for DUT testing: USB-C input, Python API, open hardware. Compact tool for labs, factories, and developers’ desks.
ioan-larionovIoan Larionov 09/22/2025 at 08:390 Comments
Scheme
Voltage control
LM51772 gives the ability to control the output voltage in two ways simultaneously: I2C and external(ATRK or DTRK). To achieve a small error, we could set a rough voltage with I2C, then fine-tune it with ATRK. The DAC signal should be attenuated and shifted to near FB, 0.8V
The goal is to manipulate the ATRK lower than 0.8V. So, adding 750mV and choosing a gain 20mV/V.
Modelling with tools.analog.com
AnalogDevices has an instrument for designing, so it's simple to generate new schematic:
Looks fine. Let's export and model in LTSpice
Modelling with LTSpice
DC sweep 0-2.5 Vin
Achieved range in simulation from 753 to 796 mV. ATRK step - 12uV, Vout step - 0.5mV
Average current control
Average current control has another architecture, so we have two options:
 Instead of a resistor, we'll use a DAC with a FET, stabilising the current in the ISET net.
External DACs
Added DACS on the board just in case something goes wrong with the built-in STM32.
PCB
Simply put everything on the board
This board connects the Nucleo board with the LM51772EVM. We're almost ready to test everything together!
