HC-SR501 PIR Sensor with Arduino
Learn how a HC-SR501 PIR Sensor works and how to interface it with the Arduino Board for detecting motion.
The PIR (Passive Infrared) sensor is widely used to detect motion and presence of objects or people in its field of view. These sensors are also known as Pyroelectric sensors or PIR motion sensors. You’ll often find them in security systems, automatic doors, and smart lighting applications. One of the most popular PIR sensors for beginners and hobbyists is the HC-SR501. It’s easy to use with Arduino and can quickly add motion detection capability to your projects. In this tutorial, we’ll understand how the HC-SR501 PIR sensor works and how to interface it with an Arduino board.
How Does a PIR Sensor Work?
A PIR sensor detects the infrared radiation (heat energy) emitted by objects in its surroundings. It doesn’t emit any radiation of its own; instead, it senses variations in IR levels.
Since every object above absolute zero (-273°C) emits infrared radiation, the human body also radiates heat, which the PIR sensor can detect. By measuring these variations, the sensor determines whether motion is present.
Key Components of a PIR Sensor
1. Pyroelectric Sensor
At the core of a PIR sensor is the pyroelectric material (such as a crystal) that responds to changes in infrared radiation.
  • When a person or object moves, the change in IR levels causes the material to generate a small electric charge.
  • The sensor converts this into a voltage signal that can trigger an alarm or output.
The pyroelectric element has two sensing slots. Each slot detects IR independently — one gives a positive output and the other a negative output. Under stable conditions, the slots detect equal IR levels, and the output remains zero.
When motion occurs (e.g., a human passes by), one slot receives more IR than the other. This differential change generates a detectable voltage signal, indicating motion.
2. Fresnel Lens
The Fresnel lens is a lightweight optical lens made of concentric grooves. It focuses infrared radiation onto the pyroelectric sensor, extending the detection range and creating a wider field of view.
This design makes the HC-SR501 capable of detecting motion across a broad area rather than just directly in front of it.
HC-SR501 PIR Sensor Module Pinout
The HC-SR501 PIR motion sensor has three pins:
VCC – Power supply (4.5V to 12V, typically connected to 5V).
GND – Ground (0V reference).
OUT – Digital output pin. This pin goes HIGH (3.3V/5V) when motion is detected and remains LOW (0V) when no motion is present.
Arduino Code
How to Interface HC-SR501 PIR Sensor with Arduino
by www.playwithcircuit.com
#include <LiquidCrystal.h> // We are using JHD 16x2 alphanumeric LCD using HD44780 controller for its controller
LiquidCrystal lcd(12, 11, 6,7,8,9);
int sensorInput = 2;   // Output for PIR sensor input for controller
int sersorReturn=0;
void setup() {
  pinMode(sensorInput, INPUT);   // declare sensor pin as input pin
  // set up the LCD's number of columns and rows:
  lcd.begin(16, 2);
  // set the cursor to (column = 0,row = 0)
  lcd.setCursor(0, 0);
  lcd.print("PIR Sensor Says:");
  // set the cursor to (column = 0,row = 1)
  lcd.setCursor(0, 1);
void loop() {
  sersorReturn = digitalRead(sensorInput);  // read input value
  if(sersorReturn == HIGH)
    lcd.print("Motion Occurs");
  else
    lcd.print("Motion Stops ");
 Project Video
To learn more checkout: How HC-SR501 PIR Sensor Works & How to Interface it with Arduino
  • 1 × arduino uno
  • 1 × 16 by 2 LCD Capacitors / Ceramic
  • 1 × 10kohm Potentiometer
  • 1 × 220 Ω Resistance
  • 1 × HC-SR501 PIR Sensor
View all 7 components
  • 1
    Interfacing HC-SR501 PIR Sensor to Arduino
    Now, let’s see how to connect the HC-SR501 PIR motion sensor to an Arduino UNO.
    The wiring is quite simple: the sensor’s OUT pin is connected to digital pin 2 of the Arduino, while VCC and GND are connected to the 5V and GND pins, respectively.
    Additionally, a 16×2 LCD display is included in the setup to show real-time status updates — such as whether motion is detected or no motion is present.
    The connections between Arduino Uno and LCD  are as follows:
View all instructions
