The mechanics
A project log for A double syringe pump for flow chemistry
Here we plan to build a double headed syringe pump setup to be used in the studies of flow chemical reactions
alfredo-marquesAlfredo MArques 07/28/2014 at 00:140 Comments
Finaly I finished the mechanical part. I´m using a piece of polyacetal plastic as a base and as a syringe holder. I´ll post the measurements later this coming week. The arduino code needs a little bit more work. As soon as I finish it I´ll post here.
