1Platformio Build
1) Prerequisites
VS Code installed
PlatformIO IDE extension (install from the VS Code Marketplace)
Git (optional, for cloning the repo)
Drivers:
Windows: CP210x or CH34x if your board uses those USB-UART chips
Linux: add udev rules (see below)
macOS: usually no extra driver needed
Linux udev (USB permissions)
sudo usermod -a -G dialout $USER # Add rules for CP210x/CH34x if needed, then: sudo udevadm control --reload-rules sudo udevadm trigger # Reboot or re-login to apply group changes
2) Get the source
# Clone (or download ZIP) git clone https://github.com/geo-tp/ESP32-Bus-Pirate.git
3) Open in PlatformIO
Open VS Code → PlatformIO Home → Open Project → select the repo folder.
Tip: The project supports multiple boards, choose the one you want.
Geo
