V1.1
09/29/2025 at 23:37 • 0 commentsChangelog
I2C
sniff🔹 More readable data, improvements.
DIO
pulldown <pin>🔹 Active pulldown resistor on given pin
SUBGHZ
load🔹 Fixes and improvements.listen🔹 RSSI to audio mapping (using I2S configured output or internal speaker if any)replay🔹 Fixes and improvement.
STANDALONE TERMINAL MODE (New)
Use
arrows up/downto scroll andescto scroll down line by line. Usetabfor command history.MISC
- Use the webflasher: https://geo-tp.github.io/ESP32-Bus-Pirate/webflasher/
- Collection of scripts: https://github.com/geo-tp/ESP32-Bus-Pirate-Scripts
- Full guide: https://github.com/geo-tp/ESP32-Bus-Pirate/wiki
V1.0 Changelog
09/26/2025 at 09:45 • 0 commentsChangelog
INFRARED
load
🔹 Load.irfiles from LittleFS (https://github.com/Lucaslhm/Flipper-IRDB)
WIFI
nmap
🔹 Improvements for services discovery. Thanks to @AndreiVladescu
SUBGHZ
bruteforce
🔹 Fixes and improvements.load
🔹 Load.subfiles from LittleFS (https://github.com/Zero-Sploit/FlipperZero-Subghz-DB)
RF24 (New mode)
scan
🔹 Search best active channel.sniff
🔹 Sniff raw frames.sweep
🔹 Analyze channels activity.jam
🔹 Jam selected channels group.setchannel
🔹 Set operating channel.config
🔹 Configure NRF24 settings.
LittleFS (Storage / Import & Export)
- Import / Export
🔹 Upload.ir,.subfiles to LittleFS.
🔹See: https://github.com/geo-tp/ESP32-Bus-Pirate/wiki/99-LittleFS
New Device Supported
- M5Cardputer ADV
Misc / Notes
- Use the webflasher : https://geo-tp.github.io/ESP32-Bus-Pirate/webflasher/
- New scripts: https://github.com/geo-tp/ESP32-Bus-Pirate-Scripts
- Visuals assets to talk about the firmware: https://github.com/geo-tp/ESP32-Bus-Pirate/wiki/99-Visual-Assets
Geo
