Hot Wire Foam Cutting
A project log for Evezor Robotics and Automation Platform
A Networked set Robotic Arms, Motion platforms, sensors and more. Easily programmed with a drag and drop interface.
anfroholicanfroholic 03/22/2017 at 05:210 Comments
Today we made the letter ‘S’ in foam.
The general frame was constructed with 2X2 and 2X3 wood pieces and a 6″ 1/2-13 bolt up the spine.
I used stainless steel wire for the element, but nichrome wire would have been a better choice.
Links to the .svg and .stl files can be found on this project’s thingiverse page
Tomorrow we will do some glass etching
