Plasma Cutting
A project log for Evezor Robotics and Automation Platform
A Networked set Robotic Arms, Motion platforms, sensors and more. Easily programmed with a drag and drop interface.
anfroholicanfroholic 04/07/2017 at 11:220 Comments
Today we plasma cut the letter E out of sheet metal.
The toolehead is a standard handheld plasma cutter. I used a small solenoid for the trigger mechanism.
The material is 12ga mild steel.
The toolpath was created in inkscape
Toolhead
See our blog post on this job at http://evezor.com/plasma-cutting/
