1Variable Inertia From Abstract Concept to the Era of Measuring the Universe
Inertia: A Millennia-Long Journey
Inertia, the ability to maintain an object’s motion, has existed since ancient times. Aristotle viewed motion as an inherent property; an object stops only when the force disappears. For thousands of years, inertia remained an abstract concept, impossible to measure.
Galileo and Newton initiated a revolutionary leap. Newton defined inertia through the first law, but humans could only measure mass indirectly. In modern physics, inertia exists more in theory than in experiment; it is still not directly quantifiable.
NKTg Law: A Great Leap in Quantifying Inertia
NKTg Law – the Law of Varying Inertia allows for the measurement of inertia. Inertia becomes a variable quantity, depending on position, velocity, and mass:
NKTg = f(x, v, m)
NKTg₁ = x · p
NKTg₂ = (dm/dt) · p
With the NKTm unit, inertia becomes a measurable entity, both theoretical and practical. NKTm is the bridge between classical thinking and modern experimentation, enabling simulation, calculation, and deployment across all physical and engineering systems.
NKTg Law is implemented in 150 leading programming languages, from Python, C++, Java, MATLAB, R, Swift, Go to PL/I, PL/SQL, ASP.NET, Assembly. This enables:
- Support for all software ecosystems, from desktop to web and mobile.
- Direct integration with inertia-measuring sensors.
- Simulation of objects from fundamental particles to planets and galaxies on a unified algorithmic platform.
Core Library & API: Global Knowledge of Inertia
Another historic advancement is the implementation of NKTg Law in 150 leading programming languages. From Python, C++, Java, MATLAB, R, Lua, Swift, Go to rarer languages like PL/I, PL/SQL, ASP.NET, Assembly, or COBOL, NKTg Law becomes a common language for modern simulation and computation systems.
This wide deployment allows:
- Support for all software ecosystems, from desktop, server, to web and mobile.
- Direct integration with sensors to measure inertia experimentally.
- Easy simulation of objects, from fundamental particles to planets and galaxies, on the same algorithmic platform.
This is supported by the Core library & API of NKTg Law on GitHub: https://github.com/NKTgLaw/NKTgLaw, which provides:
- Core implementation: core algorithms for calculating varying inertia,
- REST/gRPC API: access to inertia data and system integration,
- 150+ client wrappers: deployment support for over 150 programming languages, from infrastructure to application, from physics simulation to robotics, aviation, and astronomy.
Thus, NKTg Law becomes a global digital science platform, where inertia is no longer a theoretical concept but data that can be analyzed, shared, and applied instantly.
Historical Significance and Cosmic Vision
Quantifying inertia is a milestone of knowledge, leading humanity into a new era of understanding the universe. With NKTg Law, NKTm, 150 programming languages, and sensor systems:
- Inertia can be measured directly, no longer an abstract unknown.
- All motion models – from elementary particles to galaxies – can be simulated and predicted accurately.
- Understanding of nature and the universe enters a new era, where intrinsic properties of objects become scientific data.
Inertia, once theoretical, is now a numerical entity, opening doors for humanity to explore and understand the universe more deeply.
Conclusion
From Aristotle to Newton and modern physics, inertia has always been an abstract concept, not directly measurable. Thanks to NKTg Law and NKTm, along with 150 programming languages and sensor devices, inertia is now a practical measurable quantity, ushering in a new era of universal understanding, transforming physical knowledge from theory to data, from abstraction to measurement, from reasoning to discovery.
Nguyen Khanh Tung
