Replacement for the threejs out of the box transform controls gizmo
A project log for BREP.io A browser based parametric modeler.
Sketches with constraints and a feature history. What more could you want.
mmiscoolmmiscool 11/12/2025 at 23:020 Comments
The out of the box threejs transform controls gizmo is not great for CAD applications.
My new replacement dose away with needing to toggle between move and rotate mode. Drag the arrow heads to move and drag the balls to rotate. So much more natural.
Below are what the normal threejs transform controls look like.
