Weather Forecast with Lilygo T-Display ESP32
3 Day & Current Weather with ESP32 T-Display and openweathermap.org API
Public Chat
This weather station uses the openweathermap.org API to pull information for a 3 day forecast with the daily High/Low Temperature, Weather Description (rainy, cloudy, etc), and displays the Current Temperature and Current Weather Description. It uses the Lilygo T-Display S3R8 with ESP32 and wifi.
Update! Now includes wifi triangulation for location so you can take it on the go, mount it in your car, etc. and the weather updates accordingly.
I had a Lilygo T-Display S3R8 sitting around that came as a promotional item with some other electronics and finally put it to use. Despite the size and cheap price (under $10) of the T-Display it has wifi and bluetooth. This weather station uses the openweathermap.org API to pull information for a 3 day forecast with the daily High/Low Temperature, Weather Description (rainy, cloudy, etc), and displays the Current Temperature and Current Weather Description.
The cyan text is for the current conditions, and the data is pulled every 30 minutes which is well below the free tier API usage for openweathermap.org. If the device cannot update the data for 2 hours, a red asterisk will appear to let you know the connection has failed. The wifi, location, and API are all set during install. This was created using Cursor, which has been an interesting and quick tool to use for coding small devices like this. Overall it is a pretty simple project and a great introduction to these small devices.
Full instructions and code are available over on Github.
  • 1 × Lilygo T-Display S3R8 https://lilygo.cc/products/t-display-s3?variant=42351558590645
  • Wifi Triangulation
    JohnsonFarms.us10/14/2025 at 01:26 0 comments
    So to increase the usability of this device I added wifi triangulation so it updates the weather based off its location.
    To use this you do have to use a Google Maps API, but it uses well below the free threshold so there should be no issues.
    If the triangulation fails, the device will fall back to the location you set during install.
    The full updated code is not on GitHub.
View project log
  • 1
    Setup
    LilyGo T-Display S3 Weather Station
    A beautiful, real-time weather display showing current conditions and 3-day forecast using the LilyGo T-Display S3 and OpenWeatherMap API.
    ## Features
    - **Current Temperature** - Large, easy-to-read display in cyan
    - **3-Day Forecast** - Today's high/low plus next 2 days
    - **Weather Conditions** - Real-time weather descriptions
    - **Auto-Update** - Refreshes every 30 minutes
    - **Stale Data Warning** - Red asterisk if data is >2 hours old
    - **Clean UI** - Horizontal tile layout with optimized fonts
    - **WiFi Connected** - Automatic connection on startup
    - **Automatic Timezone** - Detects timezone from location coordinates (works worldwide!)
    - **Smart Day Names** - Accurate day-of-week that updates properly
    ## What You'll Need
    ### Hardware
    - LilyGo T-Display S3 (ESP32-S3 with 170x320 ST7789 display)
    - USB-C cable for programming
    ### Software
    - PlatformIO (or Arduino IDE)
    - OpenWeatherMap API key (free tier works great - 1,000 calls/day)
    ## Installation Instructions
    ### Step 1: Get Your OpenWeatherMap API Key
    1. Sign up at https://openweathermap.org/
    2. Navigate to **API Keys** in your account
    3. Copy your API key (or generate a new one)
    4. Free tier allows 1,000 calls/day (plenty for 30-min updates)
    ### Step 2: Clone the Repository
    ```bash
    git clone https://github.com/johnsonfarmsus/lilygo-weather-station.git
    cd lilygo-weather-station
    Or download directly from: https://github.com/johnsonfarmsus/lilygo-weather-station
    ### Step 3: Configure Your Settings
    **Edit `src/pin_config.h`** - Update WiFi credentials:
    ```cpp
    #define WIFI_SSID "YOUR_WIFI_SSID"
    #define WIFI_PASSWORD "YOUR_WIFI_PASSWORD"
    **Edit `src/main.cpp`** (lines 14-18) - Update API key and location:
    ```cpp
    #define OPENWEATHER_API_KEY "YOUR_API_KEY_HERE"
    #define LATITUDE "47.4771" // Your latitude
    #define LONGITUDE "-118.2472" // Your longitude
    **How to find your coordinates:**
    - Go to Google Maps: https://maps.google.com
    - Right-click on your location
    - Click on the coordinates to copy them
    - Or use: https://www.latlong.net/
    **Example coordinates:**
    - Seattle, WA: `47.6062, -122.3321`
    - London, UK: `51.5074, -0.1278`
    - Tokyo, Japan: `35.6762, 139.6503`
    **Why coordinates instead of city names?**
    - More accurate, especially for small towns
    - No ambiguity (many cities share the same name)
    - Automatic timezone detection works worldwide
    - Better data quality from OpenWeatherMap
    ### Step 4: Upload to Device
    **Using PlatformIO (Recommended):**
    ```bash
    # Install PlatformIO if you haven't already
    pip install platformio
    # Connect your T-Display S3 via USB-C
    # Compile and upload
    pio run --target upload
    # Optional: Monitor serial output
    pio device monitor --baud 115200
    **Using Arduino IDE:**
    1. Install ESP32 board support
    2. Select board: **ESP32S3 Dev Module** or **LilyGo T-Display-S3**
    3. Copy all files to Arduino sketch folder
    4. Install required libraries: - LVGL 8.3+ - ArduinoJson 7.0+
    5. Upload to board
    **If Upload Fails:**
    Put the device in programming mode:
    1. Hold down the **BOOT** button
    2. Press and release the **RESET** button
    3. Release the **BOOT** button
    4. Try the upload command again
    ## Configuration Options
    ### Change Update Frequency
    Edit line 20 in `src/main.cpp`:
    ```cpp
    #define UPDATE_INTERVAL_MS (30 * 60 * 1000) // 30 minutes (default)
    // Examples:
    // 15 minutes: (15 * 60 * 1000)
    // 1 hour: (60 * 60 * 1000)
    ### Change Temperature Units
    Edit line 19 in `src/main.cpp`:
    ```cpp
    #define UNITS "imperial" // Fahrenheit (default)
    // or
    #define UNITS "metric" // Celsius
    ## Display Layout
    │ 62°F Fri Sat │ ← Current temp (cyan) | Day/Date
    │ 10-04 10-05 │
    │ 72/58°F 68/52°F 61/48°F │ ← High/Low temps (yellow)
    │ Clear sky Overcast Scattered │ ← Conditions
    │ clouds clouds │
    ## Color Scheme
    - **Cyan**: Current temperature and conditions
    - **Yellow**: High/Low temperatures (when data is fresh)
    - **Red**: Temperatures when data is stale (>2 hours old, with asterisk)
    - **White**: Day/Date labels
    - **Gray**: Future forecast descriptions
    ## Troubleshooting
    ### Display Not Working
    - The T-Display S3 uses parallel I80 interface (not SPI)
    - GPIO15 must be powered (handled automatically in code)
    - Check that LVGL is properly configured
    ### WiFi Connection Issues
    - Verify SSID and password in `pin_config.h`
    - Check WiFi signal strength
    - Ensure 2.4GHz network (ESP32 doesn't support 5GHz)
    - Serial monitor will show connection status
    ### API Errors
    - Verify API key is correct and activated (can take a few minutes)
    - Check you haven't exceeded free tier limits (1,000 calls/day)
    - Ensure coordinates are in decimal format (not degrees/minutes/seconds)
    ### Stale Data Warning
    - Red asterisk (*) appears on temps if data hasn't updated in 2+ hours
    - Usually indicates WiFi connection lost or API issues
    - Device will auto-retry on next update cycle
    ## Technical Details
    ### Libraries Used
    - **LVGL 8.3+** - Graphics library for display
    - **ArduinoJson 7.0+** - JSON parsing for API responses
    - **WiFi** - ESP32 WiFi connection
    - **HTTPClient** - API requests
    ### Display Specs
    - **Controller**: ST7789V
    - **Resolution**: 320x170 pixels
    - **Interface**: 8-bit parallel I80
    - **Backlight**: GPIO38
    - **Power**: GPIO15
    ### API Usage
    Uses two OpenWeatherMap APIs:
    1. **Current Weather API** - Real-time conditions
    2. **5-Day Forecast API** - 3-hour interval forecasts (grouped by day)
    Both use latitude/longitude for precise location targeting and automatic timezone detection.
    ### Memory Usage
    - **RAM**: ~47KB (14% of 327KB)
    - **Flash**: ~1.1MB (17% of 6.5MB)
    ## How It Works
    1. **Startup**: Device connects to WiFi and syncs time via NTP (UTC)
    2. **Weather Fetch**: - Calls OpenWeatherMap Current Weather API for current conditions - Calls Forecast API for 3-day predictions - Extracts timezone offset from API response
    3. **Data Processing**: - Converts all timestamps from UTC to local time using timezone offset - Groups forecast entries by calendar date - Calculates daily high/low temperatures - Determines day-of-week from actual dates
    4. **Display Update**: - Shows current temp and conditions (from forecast API for reliability) - Displays today's high/low plus next 2 days - Updates every 30 minutes automatically
    5. **Smart Features**: - If current temp exceeds forecast high, uses current as high - Shows red asterisk if data becomes stale (>2 hours) - Adapts to any timezone worldwide automatically
    ## Future Enhancements
    Potential features for future versions:
    - Weather icons/symbols
    - Hourly forecast view
    - Multiple location support
    - Touch screen controls
    - Battery level indicator
    - Dark/light mode toggle
    ## Credits
    - Built for the LilyGo T-Display S3: https://www.lilygo.cc/
    - Weather data from OpenWeatherMap: https://openweathermap.org/
    - Uses LVGL graphics library: https://lvgl.io/
    - GitHub Repository: https://github.com/johnsonfarmsus/lilygo-weather-station
    ## License
    This project is open source and available under the MIT License.
    ## Version History
    **v1.2.0** (Current) - Automatic timezone detection
    - Added automatic timezone detection from API (works worldwide!)
    - Fixed day-of-week calculation using actual dates
    - All forecast times converted to local timezone
    - Today's high/low now uses actual forecast data
    **v1.1.0** - Coordinate-based location
    - Coordinate-based location for precise weather data
    - Proper calendar-day grouping for forecasts
    - Better handling of late-day scenarios
    **v1.0.0** - Initial release
    - Current temperature and conditions display
    - 3-day forecast with high/low temps
    - Auto-refresh every 30 minutes
    - Stale data warning indicator
    **Questions?** Visit the GitHub repository or leave a comment on this project page!
View all instructions
