Wifi Triangulation
10/14/2025 at 01:26 • 0 commentsSo to increase the usability of this device I added wifi triangulation so it updates the weather based off its location.
To use this you do have to use a Google Maps API, but it uses well below the free threshold so there should be no issues.
If the triangulation fails, the device will fall back to the location you set during install.
The full updated code is not on GitHub.
JohnsonFarms.us
