"Infrared-based sensor system for contactless monitoring of wetness and ice"
A project log for The Optical Inch
An approach to entry-level wideband spectrometry (color temperature & CRI, UV-A /UV-B dosimetry, material identification, ...)
helgehelge 07/05/2021 at 15:530 Comments
Here's an inverse solution - when detecting in a wavelength range where LEDs are the go-to light sources and consequently narrow-band, multispectral sensing is easier to do, and the spectral resolution is more sharply defined.
This goes both ways though, as a set of LED dies needs to be available for both photodiode-mode and emitting diodes.
https://jsss.copernicus.org/articles/9/133/2020/
