USB Voltage Tester
This device is used for measuring USB port voltage. Does not need a power source.
Public Chat
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
I made this device by soldering my used USB cable to a voltmeter that does not require a power source. The minimum voltage that can be measured is about 2 V. You can see the device working in this video: https://www.youtube.com/shorts/KrwWVyXyNtk
