# Pico W Remote UF2 Flashing (OTA) – By aMiscreant
### This project demonstrates how to remotely upgrade the firmware of a Raspberry Pi Pico W by downloading a `.uf2` file from a server and flashing it directly into flash memory. Unlike standard MicroPython OTA examples, this approach writes the raw `UF2 payload` to flash, effectively performing a true firmware upgrade over Wi-Fi.
**WARNING:** This method is dangerous. Writing directly to flash can permanently brick your Pico W if done incorrectly. Only use on test devices and understand the risks.
### Overview
#### Server:
The server hosts the UF2 firmware files via Flask:
```python
@app.route("/firmware/<path:filename>", methods=["GET"])
@require_key
def firmware_files(filename): """ Serve UF2 files from the firmware directory. Example: /firmware/nuke.uf2 """ return send_from_directory(UPLOAD_DIR, filename, as_attachment=True)
Files are served over HTTP with an API key. Any Pico W on the network can fetch the UF2 if it has the correct key.
## Pico W
The Pico W script handles: Connecting to Wi-Fi. Fetching the UF2 file from the server. Extracting payload blocks from the UF2. Overwriting flash memory. Rebooting into the new firmware.
**Important Flash Parameters:**
```python
FLASH_BASE = 0x10000000 # RP2040 flash base
FLASH_SIZE = 2 * 1024 * 1024 # 2MB example
UF2_PAYLOAD_OFFSET = 0x200 # skip UF2 header to raw flash data
**Firmware Upgrade Function:**
```python
def fetch_nuke_brick_mode(): url = f"http://{SERVER_IP}:{SERVER_PORT}/firmware/nuke.uf2" local_path = "/nuke.uf2"
# Download UF2 response = urequests.get(url, headers={"X-API-KEY": API_KEY}, stream=True) # ... handle download
# Read UF2 and extract payload uf2_data = open(local_path, "rb").read() payloads = [uf2_data[i + UF2_PAYLOAD_OFFSET:i + 512] for i in range(0, len(uf2_data), 512)]
# Direct flash write (dangerous!) for idx, payload in enumerate(payloads): addr = FLASH_BASE + idx * len(payload) for i in range(len(payload)): machine.mem32[addr + i] = payload[i]
# Reboot into new firmware machine.reset()
**Key points:**
Each UF2 block is 512 bytes; the first 32 bytes are header. We skip the header (UF2_PAYLOAD_OFFSET) and write the raw data. Uses machine.mem32 to write directly to flash — high risk of bricking.
**Requirements:**
Wi-Fi connection to reach the server. API key to access the UF2 files. Tested only on Raspberry Pi Pico W running MicroPython.
| Method | Description | Risk |
| Standard MicroPython OTA | Fetch `.py` files or use Git/SSH | Low |
| Custom Bootloader (Jakub Zimnol) | Switch firmware using a bootloader | Medium |
| **UF2 Direct Flash (this project)** | Fetch `.uf2`, write raw flash, reboot | **High** |
__Most existing guides update code, not firmware. This approach replaces the firmware itself.__
# **Warnings:**
### [!]️ Direct flash writes are `irreversible` if done incorrectly.
### [!]️ Always test on disposable Pico W devices first.
### [!]️ This method assumes `2MB` flash layout; adjust for other models.
# **Working Example:**
### [PicoW](https://github.com/aMiscreant/Subrosa-Pico)
### [Server](https://github.com/aMiscreant/Subrosa-Ducky)
Miscreant
