fuseholder.stl
Bench test stand for the Digikey 486-1988-ND Fuse Holder
Standard Tesselated Geometry -
244.61 kB -
10/16/2025 at 01:39
Download
5x20fuse-1x1square.stl
5x20mm fuse with 1x1x8mm square center
24.89 kB -
10/16/2025 at 02:39
Download
5x20fuse-2x2square.stl
5x20mm fuse with 2x2x8mm square center
24.50 kB -
10/16/2025 at 02:39
Download
5x20fuse-3x3square.stl
5x20mm fuse with 3x3 square center
24.89 kB -
10/16/2025 at 02:39
Download
5x20fuse-sidehole.stl
5x20mm fuse with 3mm hole perpendicular through center
44.71 kB -
10/16/2025 at 02:39
Download
5x20fuse-hollow.stl
5x20mm fuse with 3mm hole 8mm long parallel through center (hollow)
43.25 kB -
10/16/2025 at 02:39
Download
5x20fuse-1x1fillet.stl
5x20mm fuse with 1x1x8mm square center with vertical fillet
31.92 kB -
10/16/2025 at 02:39
Download
