Adding Sound and it will guide you thru the initial Setup.
A project log for meow!
meow! is a IoT Amazon Echo enabled Cat Feeder for tidbits (treats). Best used while you are tired of tickling your Cat(s). Made with ♡.
ChrischiChrischi 04/26/2017 at 18:570 Comments
Recently i came about the idea of adding Sound to meow! because no one besides of me would ever know how to set up meow!
To get it fully working i added a callback to the fauxmoESP Library to see if meow! is discovered and to play the right sound file.
The Steps are:
1. Welcome and Instructions
2. Setup complete - Trying to connect to the WiFi.
3. WiFi connected
4. Trying to help the User, saying "Alexa, search Smarthome-Devices"
5. If No 4 fails, Instruct the User what to do.
6. Setup complete + Instructions what the URL is and that there is also a Touch Button on the meow! Surface.
Sorry Guys, it's currently only in German, but I want to add English in the near future. I thought about checking the Geo-location via IP and after that "meow!" will decide which language to use.
Later (after Setup) in the Settings Menu you could change the Interface and spoken language.
Maybe I will add "meowish" to it as Easter-egg. ;-)
See it in Action (Speaker ON!):
