Suspension!
A project log for GoKart Tank
Build a real tracked vehicle out of off the shelf parts
samernsamern 04/01/2017 at 03:350 Comments
Yes, it may be finished, it may be working, but it's time to get improving. Before I install the gasoline motor and differential (and triple the power), I am adding suspension. I've 3D printed the prototype to test fit stuff before I send the drawing off for the arms to be cut out of 6mm alumimum.
