Project Log - November 13, 2025
11/13/2025 at 15:58 • 0 commentsProject Log - November 13, 2025
Prototypes arrived from JLCPCB and initial assembly/testing is underway.
Assembly completed: Pcb is now populated with components. Hand-soldering went smoothly with stencil for paste application.
Issues found and fixed:
- Case screws too short - need M2.5 x 8mm instead of 6mm (my bad)
- PN7150 NFC chip: missing trace between pins 2-3, fixed with small solder bridge
- CC1101 balun: same issue, solder bridge applied
- STM32 BOOT0 control: added thin copper wire from ESP32 GPIO to BOOT0 pin for DFU mode switching (cleaner than original design)
- Display flex cable: tore during assembly (user error), repaired with careful resoldering
Components tested and working:
- Both MCUs (ESP32-S3 and STM32G431) boot and communicate via UART
- TFT display (2.4" ST7789V3) - full color, touch, graphics
- All 6 buttons (D-pad + A/B) with proper debouncing
- RGB LED
- USB switching between ESP32/STM32 (hardware mux confirmed working)
- GPIO header
- IR transmitter/receiver
- I2C EEPROM (AT24C256)
- SD card reader
- LiPo charging circuit
- PN7150 NFC (works but code not finished for it)
- Battery fuel gauge
Still testing:
- LoRa module (868MHz) - SPI communication next
- CC1101 Sub-GHz - RF testing pending
- Full firmware integration
Next steps:
- Complete RF testing (LoRa range test, CC1101 frequency sweep {pure hell} )
- Finalize case design (adjust screw boss height) --> i just brocke and sandet the resin case 🔥
- Begin firmware development for LoRa mesh and Sub-GHz protocols
- Prepare for Kickstarter video shoot
Overall: Hardware validation looking good. Minor fixes needed for production revision but nothing blocking the February launch timeline.
Luka
