Measuring Mains Frequency (Software) — Raspberry Pi + pigpio + WebSocket
A project log for Electric time
Vintage pressure gauge hacked into a frequency meter, sensing the 50 Hz electrical grid tremors; time wavers, bends, and fades away.
dtournerDétourner 10/31/2025 at 08:550 Comments
In a previous log, I covered the hardware part of measuring mains frequency — this time it’s all about the software.
The goal: measure the local 50 Hz mains frequency in near real time, using a Raspberry Pi, a zero-crossing detector, and the pigpio library for precise timing. The Pi counts the signal edges, keeps timestamps in a circular buffer, corrects time drift using a 1 Hz PPS reference from a GPS receiver, and streams the calculated frequency over WebSocket.
The source code is on Github
How It Works
The core idea is simple:
  1. Each zero-crossing from the mains signal generates an interrupt on a GPIO pin.
  2. pigpio gives us a timestamp (in microseconds) for every edge.
  3. We store the last N timestamps (e.g. 1000 samples).
  4. Once per second (triggered by the GPS PPS), we compute:
  1. The result (current_frequency) is broadcast as JSON via a WebSocket server.
Core Components
Key Details
Real-Time Streaming
The script starts a WebSocket server (ws://0.0.0.0:8765) and sends an update once per second:
  "time_stamp": 1730362540.12,
  "last_update_time": 1730362539.89,
  "frequency": "50.013"
Any WebSocket client (Python, Node.js, browser dashboard, etc.) can subscribe to display or log the frequency over time.
Example Console Output
Base time: 1.000001 seconds (from GPS PPS)
Frequency: 50.012345 Hz (at 1730362540.123456 seconds) [1000 samples; Measured: 100.024690 Hz]
WebSocket server started at ws://0.0.0.0:8765
Client connected from IP: 192.168.1.42
(Measured: 100 Hz = zero-crossings/sec → divide by 2 → ~50 Hz mains frequency.)
Summary
This small Python script combines hardware-level timing from pigpio with a GPS-disciplined PPS reference and asynchronous streaming via WebSocket. It’s a neat way to visualize how the power grid frequency fluctuates in real time — and a solid foundation for any GPS-synchronized power-quality or IoT monitoring setup.
