The Sensor
A notable characteristic of a silicon diode is its temperature sensitivity: its forward voltage decreases by roughly 2 mV for each degree Celsius rise, maintaining a fairly linear behavior between 0 and 100 °C. Because the base-emitter junction of a transistor behaves just like a diode, individual transistors can be conveniently used as simple and reliable temperature sensors.
Okay, let's write a Python script that reads our values from the ADC first. As our XAIO board has SAMD21G18 MCUI, it has a nice 1.0V reference source inside, and we will use it, as it has 1% tolerance, and we may measure precisely
from machine import Pin, Timer, ADC
# Setup LED on pin 18
led = Pin(18, Pin.OUT) # digital output for blinking
counter = 0 # simple counter for LED toggle
# ADC setup
ADC_CONVERT_V = 1.0 / 65535.0 # conversion factor: raw ADC (16-bit) → voltage (vref=1.0V)
adc = ADC(4, vref=0) # ADC on pin A4, using internal 1.0V reference
adcVoltage = 0.0 # variable to store measured voltage
# Timer callback function
def fun(tim):
global counter, adcVoltage # make sure we update the global variables
counter += 1 # increment counter
adcVoltage = adc.read_u16() * ADC_CONVERT_V # read ADC and convert to voltage
print(adcVoltage) # print voltage to REPL
led.value(counter % 2) # toggle LED every callback (blink)
# Initialize periodic timer
tim = Timer(-1) # create a virtual timer
tim.init(period=1000, # callback period in milliseconds (1000 ms = 1 s)
mode=Timer.PERIODIC, # periodic callback
callback=fun) # function to callWe see nice outputs on the shell:
0.5708095
0.5708095
0.57056532
0.57056532
0.5708095
0.5708095
0.57056532
Nice. Now we need to add a 1-wire thermosensor to calibrate our own (made from transistor)
Hulk
Christoph Tack
