Full Assembly Language code for MPLab 8.92 (spasm) or earlier with comments.
Demo here: https://www.youtube.com/watch?v=1vhxyDxPzY0
What is it?
This is the Assembly Code file needed as per the odonodesign tutorial on how to build a 2 digit digital thermometer using the superior PIC16F628 04 chip (not the inferior A or 20MHz chip). This simple project gives you the chance to cheaply build a digital thermometer (forless than £2 ($3.50) of components) that can read and display the temperature between 0-99 Degrees Celsius.
What's included in this Digital Download?
Assembly code file ready to edit and or compile and flash to your PIC16F628. Complimentary Circuit diagram, components list and tutorial on how to build this can be found on my blog here:
https://odonodesign.com/blog/2024/05/21/how-to-make-a-temperature-monitor-for-your-home-fridge/
So take a look yourself and see just how easy it is.
Beautifully designed and highly accurate it's, the perfect educational tu
