Project Title: Symbolic Optical Logic Without Electronics — PsL-8_OEES
Summary: The PsL-8_OEES (Photonic Symbolic Logic – Optical Execution & Evaluation System) project introduces a radically different approach to symbolic computation. Instead of voltage-driven transistors, it uses colour-coded light beams and passive optical filters to implement logic gates. Designed to operate without any electronic switching, PsL-8_OEES performs symbolic logic using structured optical overlays, with output read via CMOS or CCD sensors. This makes it immune to electromagnetic interference, ultra-low power, and deterministic — a novel hardware layer for AI, control systems, and secure computing.
Details
🔌 Motivation
Conventional electronic logic relies on voltage switching and binary transistors, which are susceptible to noise, power inefficiencies, and physical limits. PsL-8_OEES offers an alternative: a logic fabric using light and colour to represent and evaluate symbolic states. With no moving parts, no semiconductors in the logic path, and no power drawn during logic execution, it's engineered for environments that require determinism, low power, and noise immunity.
🔹 Architecture Overview
Input Encoding: Converts logic states into RGB colour values.
Logic Fabric: Passive optical filters and structured masks perform logical operations (AND, OR, NOT, XOR).
Readout Layer: CMOS or CCD sensor captures resulting light pattern.
Symbol Table & Decoder: Interprets optical states into symbolic flags and digital outputs.
🌈 Symbolic Logic Encoding
PsL-8_OEES goes beyond binary, using colour combinations for multi-valued symbolic logic:
000— None (Idle) -
001— Blue: Modifier / NOT -
010— Green: False -
011— Cyan: Conditional override -
100— Red: True -
101— Magenta: Priority trigger -
110— Yellow: Multi-assertion / AND -
111— White: Global sync pulse
⚖️ Logic Gate Implementations
AND: Red and green beams overlap through a spatial mask; light only passes if both inputs exist.
NOT: Red light blocked by filter to invert state.
XOR: Destructive interference at semi-reflective layer cancels identical inputs; differing inputs pass.
All gate operations occur passively at light speed, with no switching delay or power draw in the logic layer.
🚀 Applications
Embedded edge-AI pre-processing
Autonomous drones with passive decision logic
Electromagnetic-immune control systems (space, defense)
Industrial safety monitoring
Explainable AI with symbolic logic hardware
📄 Included Files
Whitepaper: Full system summary
Symbolic Data Flow Architecture: Logical data path
Logic Fabric Layer: Physical gate design using filters
Innovation Analysis: Comparative evaluation vs. legacy logic
Architecture PDF: Modular breakdown of photonic system
Samrat Jana
