Summary: The RTEEBM is an innovative electric machine that combines the simplicity of a brushless DC motor with the controllability of wound-field excitation — without slip rings or permanent magnets. Using a rotating transformer to deliver excitation to the rotor, this design enables full electromagnetic control of torque and field response with high efficiency and robustness. It is ideal for aerospace, electric vehicles, and high-reliability industrial systems.
🔌 Motivation
Conventional brushless motors either rely on rare-earth permanent magnets (high cost, limited tunability) or use slip rings (wear, EMI). RTEEBM eliminates both by inductively coupling excitation energy into the rotor via a coaxial rotating transformer. This allows independent control of rotor excitation in a compact, brushless topology.
🔹 Architecture Overview
Stator: Traditional 3-phase winding (AC induction or BLDC-type)
Rotor: Salient or cylindrical structure with wound-field coils
Rotating Transformer: Coaxial core transmits AC excitation into rotor
Rectifier (on rotor): Converts AC to DC for the rotor field winding
Control System: Separately regulates stator drive and excitation amplitude
🔢 Key Features
Electrically excited rotor without slip rings
No permanent magnets (avoids rare-earth sourcing)
Continuous control of magnetic field strength
High reliability and long life (no brushes or contacts)
Scalable for high-power, high-speed systems
Can be integrated with wide-bandgap inverters (SiC, GaN)
🌐 Applications
Electric aircraft propulsion
Satellite and spacecraft reaction wheels
High-efficiency EV traction motors
Variable-speed industrial drives
Submersible and sealed motors (e.g., pumps, compressors)
📄 Included Files
RTEEBM: Full architecture whitepaper
Innovation Analysis PDF: Comparative evaluation vs. legacy brushless and PM motors
Architecture PDF: Modular breakdown of RTEEBM architecture
This project is open for contributions from motor designers, power electronics engineers, and researchers exploring sustainable high-performance electric machines.
Samrat Jana
