Magnetic Suspension Conical Compressor (MSCC)
Summary: A high-efficiency, oil-free compressor architecture using a magnetically suspended conical rotor with internal groove dynamics for gas compression, cooling, and adiabatic expansion — ideal for aerospace propulsion, closed-loop Brayton cycles, and compact cryogenic systems.
🔌 Motivation
Conventional turbomachinery suffers from mechanical friction, lubricant contamination, and scale inefficiencies in small formats. This project proposes a frictionless, high-speed compressor using magnetic suspension and helical groove aerodynamics to enable efficient microscale or mesoscale thermodynamic systems.
🔹 Architecture Overview
Rotor: Magnetically suspended, gas-lubricated conical rotor
Housing: Grooved cone matching rotor helix to guide laminar flow
Clearances: Micron-scale tolerances, no mechanical contact
Thermal Extraction: Outer housing grooves act as heat sinks
Expansion Stage: Tight nozzle outlet enables adiabatic expansion
Use Case: Can connect to recuperators, turbines, or fuel injectors downstream
🔢 Key Features
No mechanical contact: reduces wear, friction, and heat loss
Oil-free: suitable for oxygen or high-purity systems
Passive magnetic bearing design: simple and low power
Laminar compression: reduces turbulence and noise
Adiabatic expansion nozzle: boosts energy efficiency
🌐 Applications
Aerospace cooling loops (e.g., LPT turbine intercooling)
Cryogenic refrigeration and liquefaction systems
Waste heat recovery in closed Brayton cycles
Fuel cell air compressors
Portable heat pumps / microturbines
📄 Included Files
Zenodo Whitepaper (PDF): Thermodynamic model and rotor-housing geometry breakdown
Innovation Analysis PDF: Comparative study vs. scroll, centrifugal, and screw compressors
Architecture PDF: Modular breakdown of maglev system
This compressor platform invites collaboration with thermal system engineers, aerospace propulsion researchers, and hardware developers in high-efficiency micro-energy systems.
Samrat Jana
MECHANICUS
Simon Liu
