The original O;T project taught us a lot about what would make the perfect Nixie clock. A few years has passed since we started this initiative. While we were busy staring at the orange glow of the Neon-Argon mixture, new parts became available, our design skills evolved and the need to start fresh slowly grew.
O;TL will be a stepping stone in order to test our new design and implement new features such as:
- Compact minimalistic, all in the beloved ALTOIDS tin form factor
- Powered via USB, no more need for the 12V source.
- App/Web interface for an over the air button-less interface
- WiFi connection using the ESP8266 μController
- High accuracy DS3231 RTC with battery backup
- The BME280 environmental sensor
- Pressure,
- Humidity
- Temperature
opeRaptor
flamefire
Daniel Knezevic
Spencer
zaphod
At last a USB nixie power supply (with a flyback transformer?). Do you have figures for efficiency/current draw? I plan a slightly larger USB nixie clock. I also plan a LiPo powered clock. I could use a commercial power supply (Taylor Edge springs to to mind), but I would very much like to build it right on to the PCB.
I plan a lot of things, but I have a lot of skill sets to learn. Slowly I am getting there.
