🦆 OverQuack
Advanced HID automation platform (Rubber Ducky style) with wireless control and Pico support.
🔗 Project URL
https://github.com/VexilonHacker/OverQuack/
Architecture & File Layout
OverQuack runs CircuitPython on Pico devices to execute DuckyScript payloads and handle HID logic.
Runtime
CircuitPython interpreter + HID/gadget logic.
Storage (CIRCUITPY)
/OverQuack_src/– interpreter, runtime, helpers/OverQuack_STORAGE/– payloads, keyboard layouts, keycodesconfig.json– central config (payloads, AP, pins, ports)
Client
OverQuack_client.go – manages Pico W remotely via HTTP/API.
Config Highlights
- DEFAULT_PAYLOAD – auto-executed payload filename
- BOARD.controll_mode_pin – GPIO for USB role switching
- AP.ssid/password, ip_address, ports – network config for Pico W
- enable_auto_reload – auto-reload on file change (dev)
Scripting & Payloads
- Modular payloads:
IMPORT otherstage.oqs - Functions, loops, IF/ELSE, arithmetic, variables
- String blocks:
STRINGLN_BLOCK/STRING_BLOCK+DISABLE_STRIP/ENABLE_STRIP - Hold/Release keys:
HOLD/RELEASE/RELEASE_ALL - Mouse API:
MOUSE_MOVE/CLICK/SCROLL/BACKGROUND_JIGGLE_MOUSE
Runtime Variables & Generators
- Network:
$_SSID,$_PASSWD,$_BSSID - Random generators:
$_RANDOM_NUMBER:n,$_RANDOM_CHAR:n,$_RANDOM_INT
Wireless API (Pico W / Pico 2 W)
Endpoints
GET /payloads – list filesPOST /payloads – uploadGET /payloads/{name} – downloadDELETE /payloads/{name} – removePOST /run/{name} – execute payloadFor lab use only – minimal API, no auth by default.
Developer Workflow
- Write
.oqspayloads locally - Upload & trigger via
OverQuack_client.go - Non-wireless Picos: copy payloads to storage, toggle mode pin
- Debug via
PRINTmessages to serial console
Serial Debugging
picocom -b 9600 /dev/ttyACM0
Windows: PuTTY/Tera Term. PRINT outputs are colorized.
Layouts & Internationalization
- Add layouts:
keyboard_layout_<LANG>.py/keycode_<LANG>.py - Register in runtime map, use
SELECT_LAYOUT <NAME>
Safety & Ethics
- Default storage mode prevents accidental HID injection
- Test only authorized systems
- Secure API with token/password for wireless use
Contributions & Ideas
- Authenticated API layer
- Desktop GUI for payload management
- Safe payload gallery
- Unit tests & layout expansion
For more details and better documentation check OverQuack repository
VexilonHacker
Kutluhan Aktar
Katsumi
Thomas
