Hackaday.io Hackaday.io
Sign up Log in
SOLAR BJT charger SEE THE VIDEO
My idea is to build a small solar panel using 24 power transistors in a TO3 package.
gfresourcesvideogfresources.video
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
Public Chat
2.7k views
0 comments
7 followers
  • Description
  • Details
  • Files 0
  • Components 1
    • View all
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
Public Chat
2.7k
0
7
8
Team (2)
  • gfresourcesvideogfresources.video
  • maxMax
Join this project's team
  • Video
completed project
hardware
This project is submitted for
  • Component Abuse Challenge
This project was created on 11/11/2025 and last updated 3 months ago.
Description
My idea is to build a small solar panel using 24 power transistors in a TO3 package. To do this, I'll uncover the transistors so the silicon die is exposed and connect the collector - base and emitter - base junctions in parallel to generate a higher current. I'll use 25 transistors, which I'll attach to an insulating support with screws, and made the electrical connection in the other side by wrapping metod. After some research, I decided to arrange five series of five transistors in parallel to achieve a specific voltage and current. I then had to design a small step-up switching device to raise the voltage to 5V so I could use it to charge a smartphone. This idea and implementation is purely experimental obviously, a solar panel has a very different energy output, but I wanted to demonstrate how a handful of transistors can be used in a very alternative way.
Details
Components
  • 25 × Power NPN BJT
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
Electrical timer supporting DST & holidays and voltage-based grid management.
Project Owner Contributor
WiseTimer Switch
ralph-doncasterRalph Doncaster
Supplyframe DesignLab: 2022 Hackada…
A low cost and high efficiency Maximum Power Point Tracking (MPPT) charge controller with multiple inputs for solar panel setups.
MultiMPPT
leonardo-wardLeonardo Ward
Run Xiaomi Thermometer LYWSD03MMC with a supercapacitor and mini solarpanel.
Solar powered Bluetooth Thermometer with Supercap
martmetMartMet
The 2017 Hackaday Prize
A perpetually running wireless sensor mote.
Open SolarMote
dhqdhq
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "SOLAR BJT charger SEE THE VIDEO", please tell us the reason.
Send message
Remove Member
